GritHound Posted June 28, 2022 Author Share Posted June 28, 2022 Finished up the gearbox today! Hoping the time/effort invested will payoff for years to come. Link to comment Share on other sites More sharing options...
GritHound Posted July 7, 2022 Author Share Posted July 7, 2022 Got the Engine broken down and getting it ready for the machine shop next week. I can't believe how clogged the lifters were, I'm guessing very little oil was making its way around the head and he never changed the oil. Link to comment Share on other sites More sharing options...
GritHound Posted July 14, 2022 Author Share Posted July 14, 2022 Ball joint removal day is always a good time. Hate you all missed it. Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 14, 2022 Share Posted July 14, 2022 1 hour ago, GritHound said: Ball joint removal day is always a good time. Hate you all missed it. Nope! Did a buddies WJ the other day. Hated it. Link to comment Share on other sites More sharing options...
GritHound Posted August 10, 2022 Author Share Posted August 10, 2022 I was able to find a few cool parts on my day off today. Should clean up nicely. Link to comment Share on other sites More sharing options...
GritHound Posted December 31, 2022 Author Share Posted December 31, 2022 Picked up the head from the machine shop was able to get it back together this week. I decided to go ahead an paint it so I could see how the coloring would turn out. I'm picking up the block next week so hoping to get the engine put together and painted this month. I'm liking the metallic burnt orange color can’t wait to see once completed. Thought I would take a couple of closeups. You have clean these covers thoroughly before painting. The pits collect oil and will birds eye your paint. 500° Primer Link to comment Share on other sites More sharing options...
GritHound Posted September 29, 2024 Author Share Posted September 29, 2024 Finally back on the restore. Working on the block and crankshaft. Engine 30 over bore and 258 crankshaft 30 mains 30 rods resurfaced. Link to comment Share on other sites More sharing options...
89 MJ Posted September 29, 2024 Share Posted September 29, 2024 Glad you're back! That color is super cool. Why the 258 cam? Link to comment Share on other sites More sharing options...
GritHound Posted September 30, 2024 Author Share Posted September 30, 2024 7 hours ago, 89 MJ said: Glad you're back! That color is super cool. Why the 258 cam? haha. I meant crank. Corrected. Thanks Link to comment Share on other sites More sharing options...
89 MJ Posted September 30, 2024 Share Posted September 30, 2024 Gotcha. That makes more sense haha Link to comment Share on other sites More sharing options...
GritHound Posted November 11, 2024 Author Share Posted November 11, 2024 Crazy issue with the Crankshaft Caps. I had the crankshaft mains and rods journals resurfaced to 30 and had to buy oversized bearings. Using my caps from the orginal 4.0 the clearance on the mains were fine but once I tightened to spec the crankshaft would not move. After a lot of measuring, I noticed wear on the side of the #3 bearing where it was making contact with the crank. It turned out that the oversized #3 bearing did not have enough side clearance due to how the crank cap holes were orginally machined. When tighten it was driving the bearing into the wall of the crankshaft. I had to pull the caps from the 258 which were machined correctly. Now its moving perfect! Link to comment Share on other sites More sharing options...
GritHound Posted November 19, 2024 Author Share Posted November 19, 2024 258 Crankshaft Spacer I couldnt find many pictures or actual details on the crankshaft spacer so wanted to provide some insight for others. Most people make their crankshaft spacer or buy one from Hesco #HESBS (easier option). I chose to make mine from the balancer I pulled off the 4.2 engine. Few tips for ensuring you get it right the first time. Get the harmonic balancer installation (1/2-20 thread) and removal tool, if you don't have them. Should be able to rent for free at any auto store. Put a light coating of grease on the crankshaft and make sure the woodruff keys are installed and not damaged. You should loosley fit the timing cover, install the balancer to center it in the seal, tighten the cover screws and pull the balancer back off then torque all timing cover screws to spec. If you don't do it this way you could have problems with alignment or tightening the screws that sit behind the balancer. When using the installation tool, make sure to add the spacer to ensure you are able to get over the nose of the crankshaft; otherwise the tool will bottom out on the nose and not let you push the balancer back far enough. Once you get the balancer past the nose front, go slow. You may need to back it off a few times to get the keyhole lined up before finishing it. The balancer should sit flush with the front of the engine once installed. Note: I put a couple of the torque coverter bolts in the back of the engine and braced a metal bar against the engine stand to prevent spin while torquing the balancer bolt to 80ft-lb. Link to comment Share on other sites More sharing options...
GritHound Posted December 11, 2024 Author Share Posted December 11, 2024 She's starting to look like an engine again! Time to wrap it up and get started on the cargo and passenger floor pans! Link to comment Share on other sites More sharing options...
