Michael Rice Posted December 11, 2021 Share Posted December 11, 2021 Without having to pay an acupuncturist again next week, is there a quick link to the color / function of the wires going into the back of the fuse block for a '89 MJ. I'm replacing the original fuse block with an aftermarket one. Thanks in advance. Link to comment Share on other sites More sharing options...
garyweb3 Posted December 11, 2021 Share Posted December 11, 2021 Where did you get an aftermarket fuse block from? Link to comment Share on other sites More sharing options...
Michael Rice Posted December 11, 2021 Author Share Posted December 11, 2021 Painless Performance, a universal type. P/N 30003. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 12, 2021 Share Posted December 12, 2021 Short of having the factory diagram and/or a donor fusebox/C100 assembly...... Link to comment Share on other sites More sharing options...
boxyjeep Posted December 12, 2021 Share Posted December 12, 2021 Unbolt the existing fuse block, unplug it from the engine side. Put them side by side on the drivers floor and remove each pin one-by-one to replace. Also, why did you buy a replacement? Were your pins shot (these can be replaced--parts on Del City), or was the fuse block itself plastic melted? Link to comment Share on other sites More sharing options...
Michael Rice Posted December 13, 2021 Author Share Posted December 13, 2021 Thanks. Not as simple as it seems as the pins don't remove easily. The new unit does not require the pins. The original is melted in places, and needs replaced. Microsoft Word - 30003.doc (painlessperformance.com) Link to comment Share on other sites More sharing options...
cruiser54 Posted December 13, 2021 Share Posted December 13, 2021 Cut and install new ends? Link to comment Share on other sites More sharing options...
oleskool Posted December 13, 2021 Share Posted December 13, 2021 5 hours ago, Chargum85 said: Unbolt the existing fuse block, unplug it from the engine side. Put them side by side on the drivers floor and remove each pin one-by-one to replace. Also, why did you buy a replacement? Were your pins shot (these can be replaced--parts on Del City), or was the fuse block itself plastic melted? Link to get new pins. I’m about to do the same. I did buy a donor fuse box in good shape. Link to comment Share on other sites More sharing options...
m2bandit Posted December 13, 2021 Share Posted December 13, 2021 6 hours ago, Chargum85 said: Unbolt the existing fuse block, unplug it from the engine side. Put them side by side on the drivers floor and remove each pin one-by-one to replace. This is the way. 2 hours ago, Michael Rice said: Thanks. Not as simple as it seems as the pins don't remove easily. The new unit does not require the pins. The original is melted in places, and needs replaced. Microsoft Word - 30003.doc (painlessperformance.com) It can be done with small screwdrivers on each side, there is however a tool to make it easier. Shove the green one of these down in there on each side of the terminal https://amzn.to/3DMFrhh I recommend replacing the connectors while you're at it because they're likely brittle by now. 1 hour ago, oleskool said: Link to get new pins. I’m about to do the same. I did buy a donor fuse box in good shape. Pack-Con III Series Terminals 16-14 Gauge Female For GM https://amzn.to/3GGyiRs Link to comment Share on other sites More sharing options...
Michael Rice Posted December 13, 2021 Author Share Posted December 13, 2021 Thank you all for your advice. Link to comment Share on other sites More sharing options...
