Whitaker717 Posted November 10, 2021 Share Posted November 10, 2021 Hi guys, I think it’s time to end my Comanche experience. I blew a head in my engine and don’t really feel like putting more money into it. Plus my wife is about to kill me. This is currently at a shop while I figure out what to do. The color is briarwood metallic but got a crappy paint job from a guy. All the bodywork is done and solid though. It is the 4.0L with 4x4 and automatic in the floor. I have put thousands into this thing for this to happen. Here is what I do to it: -New radiator -clutch fan -water pump -thermostat -alternator -all new brakes front tires back. Pads rotors, calipers, lines -headliner -rear shocks -newer tires - roll bar -new radio from Best Buy -plugs, wires, cap i am hoping to get 6-8k out of it although that might not be realistic. Obviously it’s not perfect but if someone has engine knowledge it won’t take much to get it going. I will attach a few pictures of him. Shoot me an offer. I do have more pictures of the work that’s been done too Link to comment Share on other sites More sharing options...
tugboat95 Posted November 10, 2021 Share Posted November 10, 2021 You done that much work to, a head gasket is about 50 worth of gasketing and about a day give or take. New head boltsxare recommended but not required.1989 Eliminator4.0L 5 speed2wd Link to comment Share on other sites More sharing options...
tugboat95 Posted November 10, 2021 Share Posted November 10, 2021 Its a beautiful truck.1989 Eliminator4.0L 5 speed2wd Link to comment Share on other sites More sharing options...
Whitaker717 Posted November 10, 2021 Author Share Posted November 10, 2021 According to my mechanic, coolant has went down into the bearings. He says that it will cost more to rebuild it then to put in a loaner engine. I’m not sure if that’s true or not. Link to comment Share on other sites More sharing options...
FrankTheDog Posted November 10, 2021 Share Posted November 10, 2021 Who changed out the radiator, water pump and thermostat? If it was your mechanic he owes you a new engine. Link to comment Share on other sites More sharing options...
Whitaker717 Posted November 10, 2021 Author Share Posted November 10, 2021 It was the same mechanic. I actually blame the guy I got from. He had it sitting for along time behind his garage. I knew it was bad for them but I didn’t think this would happen. Link to comment Share on other sites More sharing options...
89 MJ Posted November 11, 2021 Share Posted November 11, 2021 How much were you quoted to put an engine in the truck? You could probably get a used, known good engine for $600 or less and probably have about $1000-$1500 in labor in putting it in. At least that way it would be worth more as a running and driving truck if you still want to sell it, or you would be able to drive it some. Link to comment Share on other sites More sharing options...
FrankTheDog Posted November 11, 2021 Share Posted November 11, 2021 I’ll still put my money on the mechanic not burping the system correctly. I’ve pulled engines that were sitting for some time and never had issues. I have seen a ton of XJ’s for sale with new water pumps and radiators and blown head gaskets. “Easy fix” Except that the rear piston is usually starting to melt by the time it gets pulled over. Link to comment Share on other sites More sharing options...
FrankTheDog Posted November 11, 2021 Share Posted November 11, 2021 How long did you drive it before the radiator change? Link to comment Share on other sites More sharing options...
Whitaker717 Posted November 11, 2021 Author Share Posted November 11, 2021 On 11/11/2021 at 12:03 AM, 89 MJ said: How much were you quoted to put an engine in the truck? You could probably get a used, known good engine for $600 or less and probably have about $1000-$1500 in labor in putting it in. At least that way it would be worth more as a running and driving truck if you still want to sell it, or you would be able to drive it some. Expand He is looking for one now. He had a lead on one for 800.00. He was wanting more info on the engine though. Link to comment Share on other sites More sharing options...
Whitaker717 Posted November 11, 2021 Author Share Posted November 11, 2021 On 11/11/2021 at 12:11 AM, FrankTheDog said: How long did you drive it before the radiator change? Expand If I remember right not very long. It was in for some basic maintenance and if I remember one of the ports where a hose attached was rusted and leaking. We just decided to change out the everything when he had the radiator out. Like water pump, thermostat and clutch fan. Link to comment Share on other sites More sharing options...
tugboat95 Posted November 11, 2021 Share Posted November 11, 2021 Contact this guy. Has usually has several engines in the 500 to 600 dollar range.https://www.facebook.com/jeepjunkie/1989 Eliminator4.0L 5 speed2wd Link to comment Share on other sites More sharing options...
tugboat95 Posted November 11, 2021 Share Posted November 11, 2021 You can go get or he ships anywhere in the world.1989 Eliminator4.0L 5 speed2wd Link to comment Share on other sites More sharing options...
FrankTheDog Posted November 11, 2021 Share Posted November 11, 2021 On 11/11/2021 at 12:56 AM, Whitaker717 said: If I remember right not very long. It was in for some basic maintenance and if I remember one of the ports where a hose attached was rusted and leaking. We just decided to change out the everything when he had the radiator out. Like water pump, thermostat and clutch fan. Expand But it wasn’t overheating? Link to comment Share on other sites More sharing options...
Whitaker717 Posted November 11, 2021 Author Share Posted November 11, 2021 On 11/11/2021 at 1:06 AM, FrankTheDog said: But it wasn’t overheating? Expand I believe it was. That’s one of the reasons it was in the shop. But I had fluid in my driveway and couldn’t figure out where it was coming from. That’s where he found the leak. He replaced everything and then did a flush and fill. Link to comment Share on other sites More sharing options...
FrankTheDog Posted November 11, 2021 Share Posted November 11, 2021 So the head gasket could’ve been blown before he did all the work and that’s why it was parked? Link to comment Share on other sites More sharing options...
Whitaker717 Posted November 11, 2021 Author Share Posted November 11, 2021 I don’t think so because I drove it around for a couple thousand miles after I got it. Looking back though I do believe it was leaking or something because after the flush and fill my coolant wasn’t bright green it was more dark color. I think it was a ticking Bomb and didn’t realize it. Link to comment Share on other sites More sharing options...
Pete M Posted November 11, 2021 Share Posted November 11, 2021 you'll want to mention a location Link to comment Share on other sites More sharing options...
Whitaker717 Posted November 11, 2021 Author Share Posted November 11, 2021 On 11/11/2021 at 2:29 AM, Pete M said: you'll want to mention a location Expand Sorry Pete, I fixed it. Link to comment Share on other sites More sharing options...
Archived
