Taillight assembly damage
1 hour ago, Pete M said:
talk to a body shop. :L:  they can work miracles to pull that back out into shape.  :grinyes:
Including the bent bed side? Also, I'm trying to spend the least amount possible.
Would it be possible for me to cut out the bent part, put heat to it then
hammer it back into shape?
Edited by Virginia
adding info
absolutely. :L:  now, I don't know what that all would cost out of pocket, but I do know that if the steel it there, it can be reshaped.  :D
if it turns out to be an outrageous price, I have a few beds for sale in the classifieds.
A lot of people would prefer to build from new steel instead of trying to reform the twisted metal that is there. If it stretched the steel it’s going to need real finess to shrink it back again and get it back to the correct shape. If your only goal is to make the taillight fit again then sure, you can get behind it and push it out, or weld studs to it and pull it out with a slide hammer. But if you pull or push on the wrong part of it, you can make more work for someone who has to go in and correct all your hammer marks as well as the original damage.
My experience pushing dents out from behind on our fleet trucks is that it usually just results in a bump inside the dent. There’s almost never enough clearance on the inside to push the dents out properly.
I have on more than one occasion had hoods that were badly bent, and the only used hoods were  in such bad shape that the body shops doing the work refused to even mess with them. In both instances, they straightened the bent hoods so well that, even knowing they were damaged and where, I was unable to see where they had been repaired.
Virginia, you probably don't need to cut anything out or off. I can't imagine how that would make anything easier. I think it has to be easier to work with it intact. Are you familiar with stud welders? They are used in body work to allow attaching a slide puller without drilling holes in the sheet metal. Thin studs (sort of like the shanks of pop rivets) are welded onto the dented surface. Heat the surface up, attach a slide hammer, and gradually pull out the dent.
https://www.harborfreight.com/stud-welder-dent-repair-kit-61433.html?_br_psugg_q=stud+welder
My son is a welder. I'll talk to him about that.
