luckycamper Posted October 18, 2021 Posted October 18, 2021 As title states, I’m currently stranded and the comanch won’t stay running fml. Was running fine today but when i got back in my truck I was met with dread. It starts briefly and wants to immediately stall until i push the pedal in and then it begins to violently shake before stalling. I had an extra fuel filter in my bed for times like these so i just through that one on. Tried it a few more times and it bucks and sputters out just the same. I’m hoping perhaps someone can chime in with a similar experience and possible solution though I know it could be a myriad of things. I’ve been searching and turning through these forums for the past few hrs but w/o every tool being available to me its hard to diagnose. To sum up: was driving fine today, went to start it up again and engine bucks then stalls.
luckycamper Posted October 18, 2021 Author Posted October 18, 2021 update: got it running rough in neutral. When I put it in gear, the idle gets erratic and it wants to stall. I moved forward a little bit but by this time i’m suspecting something more internal.
Pete M Posted October 18, 2021 Posted October 18, 2021 what tools do you have? any carb cleaner? any means to pour a wee bit of gas into the TB?
luckycamper Posted October 18, 2021 Author Posted October 18, 2021 6 minutes ago, Pete M said: what tools do you have? any carb cleaner? any means to pour a wee bit of gas into the TB? hey Pete, luckily I have most of my tools in my bed (wrenches, sockets, basic stuff). I just don’t have anything to test vacuum, fuel pressure, etc. Finally managed to talk the gf into picking me up. Nxt dinner date on me. I’m going to try and read up as much as possible and rally for tomorrow morning.
luckycamper Posted October 18, 2021 Author Posted October 18, 2021 update2: have since abandoned the chariot. Before I shut her off I could hear a noticeable hollow ping. background info: bought the truck last month. I wouldn’t say I trust the previous owners abilities or choice in parts but they did say they replaced distributor cap, plugs, wires within the last year.
eaglescout526 Posted October 18, 2021 Posted October 18, 2021 Hmm 2.5L as well. I’m curious about some of the other things about it.
luckycamper Posted October 18, 2021 Author Posted October 18, 2021 49 minutes ago, Pete M said: hollow ping? yea, doesn’t sound like the common engine tick or spark knock. I’ll try to take a video tomorrow before I start digging more into it.
eaglescout526 Posted October 18, 2021 Posted October 18, 2021 Is it the exhaust cooling off perhaps that you hear? I usually hear a hollo ping after stopping the engine. What color is the coolant?
luckycamper Posted October 18, 2021 Author Posted October 18, 2021 30 minutes ago, eaglescout526 said: Hmm 2.5L as well. I’m curious about some of the other things about it. So many things. I keep finding loose connectors, vacuum hoses, etc and have just been trying to knock out one thing at a time. Currently been refreshing grounds as I also suspect a grounding issue somewhere. Previous owners replaced many parts w budget brands so I’m basically doing cleanup along with everything else. This renix 2.5 is a new beast to me so its a bit of a challenge trying to figure out how things are supposed to be but i’m getting there.
luckycamper Posted October 18, 2021 Author Posted October 18, 2021 5 minutes ago, eaglescout526 said: Is it the exhaust cooling off perhaps that you hear? I usually hear a hollo ping after stopping the engine. What color is the coolant? the sound is while the engine is running in neutral. i haven’t checked the coolant yet but i will in the morning. I hope it is still green.
eaglescout526 Posted October 18, 2021 Posted October 18, 2021 Sounds like a blast. I’m here to help as I think I took up being the resident 2.5L expert haha. I always ask everyone about the coolant as I’ve had similar issues and if a head gasket hasn’t been done since the MJ left the factory, it will buck and stall to the point where you probably can’t drive any more.
fiatslug87 Posted October 18, 2021 Posted October 18, 2021 In case you haven't come across this post with technical and parts manuals yet.
luckycamper Posted October 18, 2021 Author Posted October 18, 2021 46 minutes ago, fiatslug87 said: In case you haven't come across this post with technical and parts manuals yet. thanks man. I did find that page awhile ago and have the fsm saved on my phone!
luckycamper Posted October 18, 2021 Author Posted October 18, 2021 10 hours ago, eaglescout526 said: Sounds like a blast. I’m here to help as I think I took up being the resident 2.5L expert haha. I always ask everyone about the coolant as I’ve had similar issues and if a head gasket hasn’t been done since the MJ left the factory, it will buck and stall to the point where you probably can’t drive any more. Really appreciate it fine sir. I got a ride out here this morning and going to see what i can manage. I’ll chk the coolant and take a video for audio.
eaglescout526 Posted October 18, 2021 Posted October 18, 2021 No problem. Look forward to any updates.
luckycamper Posted October 18, 2021 Author Posted October 18, 2021 -coolant is good. -the airbox/filter looks to be getting oiled a bit so i checked the pcv valve and it is not the correct one for the 2.5 (not sure if it matters). There is movement in it, not necessarily as much as i’d expect -first video was too long going to try again
eaglescout526 Posted October 18, 2021 Posted October 18, 2021 So that front valve is correct. PN is J8132309 -> 33001239. Only 86 uses that set up so we’re in for 86 oddities.
luckycamper Posted October 18, 2021 Author Posted October 18, 2021 2 minutes ago, eaglescout526 said: So that front valve is correct. PN is J8132309 -> 33001239. Only 86 uses that set up so we’re in for 86 oddities. ok good to know. I was just going by auto parts store websites. I know, nvr trust em.
eaglescout526 Posted October 18, 2021 Posted October 18, 2021 Yeah they’re hard to trust but as long as you have a part number to reference, you should be good to go.
luckycamper Posted October 18, 2021 Author Posted October 18, 2021 Managed to get home i think by pure luck—green lights and all. Truck stalled a few times and it shook the whole ride. I have some videos (excuse the quality) to demonstrate the sound the engine makes in neutral and while in gear. IMG_9641.MOV
luckycamper Posted October 18, 2021 Author Posted October 18, 2021 few more while in gear IMG_9644.MOV IMG_9645.MOV
eaglescout526 Posted October 18, 2021 Posted October 18, 2021 Your ISA is missing it’s adjustment screw. Miracle it’s even idling. I hear a vacuum leak, big one actually. And you’re battery light is on lol.
luckycamper Posted October 18, 2021 Author Posted October 18, 2021 After I got home, I popped the hood and there was a little smoke coming from the exhaust manifold. Idk yet if this is a cause of my troubles or just an effect of something else and driving it the 15min back home. My experience driving it home was that it would want to die as soon as i lifted off the gas/felt like it was about to lose all power. To keep it from stalling I’d crush the pedal all the way down and it would slowly catch up, low idle speed.
