LCA Shims
eaglescout526
1 minute ago, Strokermjcomanche said:
Unless you were specifically trying to buy from somebody on here, eBay has them.
Dang, looks like I need to change up my search terms. Great find!
1 minute ago, fiatslug87 said:
What do you need?
Great question actually...All I know is my caster is about 5* out from spec due to going to 235's and I was told by one of our alignment techs that itll take a good number of shims to get it correct.
1 minute ago, Pete M said:
caster doesn't change with a tire swap.  :thinking:
Nope and I’ve been battling this issue since 2017 according to all the alignment paperwork I have had. At some point I’ll have to suspect the 2wd beam has some metal fatigue but I honestly have no idea.
I can't remember where, but somewhere on the web I found a pattern drawing for these shims; went through the scrap pile at work, and ended up making mine out from an old concrete saw blade. It's just shy of 1/8", put those in to free up some thin stock ones instead of buying more.
