I have a 1988 Comanche pioneer that I just bought and when I turned the wheel all the way to the right I heard a pop/click sound and then my steering wheel had a little bit of play but my tires weren’t moving. I had to pry the sway bar off of the track bar in order to have motion in my steering wheel again and be able to move the wheels. I’m wondering what the previous owner did, but more so how I can fix it.  Hopefully the pictures explain it better than I did. Thank you for the help
first picture is before and second two are after I turn all the way to the right. Last one is upside down but a panned out view of the front end.
25 minutes ago, ghetdjc320 said:
Bent drag link. May have gotten bashed on a rock or something. There should be plenty of clearance between the tie rod end and track bar mount
Thank you, I’ll try replacing that first. Any chance it could have messed with anything else the drag link is attached to?
