Hey guys got an issue. In the mornings the truck was sputtering, so I decided to start by changing out the idle air control valve. Now the engine is receding up so high it sounds like it will explode. I took it for a drive to see if it would reset and nothing. It’s even shifting funny now. What in the world is going in here
Just trying to learn. I don’t have a lot of fancy tools for testing connections. The way it sputters tells me from my little knowledge it’s around the throttle body, so the iac or the tps. Runs great when it warms up.
what fancy tools do you need to check connections?
Did you check out my Tips and read the introduction to each one? That might help with your understanding their importance.
