So I didn't waste any time and put my new REM to work and found out the IAT sensor is pretty much dead. The REM constantly reads 246F, and my multimeter can't even get a resistance reading out of the sensor. I've read elsewhere that there's a GM sensor that's pretty close in terms of specs and ohms. Anybody ever tried it?
2 hours ago, cruiser54 said:
Someone will chime in with a TOMCO number shortly.
Have you tried cleaning it?
I was thinking about it, but wondered if it was worth it since I get no reading from it... Wouldn't a dirty sensor at least have a little resistance? Mine actus like an open circuit...
  • 3 weeks later...
So I went with a GM #2309506751-equivalent sensor from Rockauto with matching pigtail. I installed it in the airbox lid, and with the truck sitting for a while, I got a 63 degrees F water temp and about 61-62 degrees F air temp readings according to the REM, so way within the error margin IMO. Looks like a worthy replacement!
  • 4 months later...
So you installed this in the airbox lid to replace the one in the intake?
The images of the parts on rockauto don't seem to match. The pigtail has some protrusions that determine orientation, that I don't see accommodated on the sensor.
The photo from my previous post is of the parts I actually used, and worked perfectly. If you check the next photo on RockAuto, you clearly see the notches to orient the connector properly.
  • 11 months later...
On 27/9/2021 at 11:44, OldSch88L said:
Así que elegí un sensor equivalente a GM #2309506751 de Rockauto con coleta a juego. Lo instalé en la tapa de la caja de aire, y con el camión sentado por un tiempo, obtuve una temperatura del agua de 63 grados F y lecturas de temperatura del aire de aproximadamente 61-62 grados F de acuerdo con el REM, por lo tanto dentro del margen de error de la OMI. ¡Parece un reemplazo digno!
hello,
I would like to know where exactly did the installation. could you attach a photo? And I would like to know if the car is consuming more fuel since the change? I would appreciate your response and references. I have a jeep xj 87
