Marjorie Ricci
Everything posted by Marjorie Ricci
  1. hello, I would like to know where exactly did the installation. could you attach a photo? And I would like to know if the car is consuming more fuel since the change? I would appreciate your response and references. I have a jeep xj 87
  2. hello, I would like to know where exactly did the installation. could you attach a photo? And from what I understand the car is consuming more fuel since the change? I would appreciate your response and references. I have a jeep xj 87
  3. hello, I would like to know where exactly did the installation. could you attach a photo? And from what I understand the car is consuming more fuel since the change? I would appreciate your response and references. I have a jeep xj 87
  4. hello, I would like to know where exactly did the installation. could you attach a photo? And from what I understand the car is consuming more fuel since the change? I would appreciate your response and references. I have a jeep xj 87
  5. Hi,
    I have a jeep xj 87 and I want to change the IAT sensor. I have read the comments and understand that it is discontinued 33002382. Could you tell me which model I can buy to adapt?
    1. DirtyComanche
      DirtyComanche
      The only info I have is in the threads I've seen you've read and replied to.  I do not run a stock Renix injection system so the IAT I am using (a GM one) may not have the right threads for your application.  If you get one with the larger threads you can drill and tap your intake manifold for them, but to do it and ensure you won't get aluminum pieces into the engine you will have to remove the manifold and clean the inside of it.
      Does that one not work?  They almost never fail.
