knever3 Posted September 7, 2021 Share Posted September 7, 2021 I want to rebuild my steering column with a new turn signal lever (the one I have currently is aftermarket and is not quality) turn signal return spring is broken. The whole turn signal lever has too much play and I would like to replace it. It is very difficult to operate the bright lights as well. The key tumbler drags a little and seems to be out of adjustment because it seems to start better if I don't turn it all the way, if that is what is happening. The Renix takes forever to start so it could be something in my head. The steering column is a 1990. I would like leads on the OEM springs, multifunction switch (stalk and actual buried piece in the column) and also horn spring and plunger. I went from the 2 spoke steering wheel to the one with the horn button and I don't have a clue what I need. I see that it requires a cup and spring and plunger so I need to get that lined up before I pull it apart. Yeah it's a lot, but I would like quality parts if they are still available. If someone has a parts diagram with part numbers that would really help, especially with the horn parts. Thanks!! Link to comment Share on other sites More sharing options...
acfortier Posted September 7, 2021 Share Posted September 7, 2021 There's a parts catalog for 1990 here: https://xjjeeps.com/ Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 7, 2021 Share Posted September 7, 2021 Go GM with the column parts. Link to comment Share on other sites More sharing options...
knever3 Posted September 7, 2021 Author Share Posted September 7, 2021 Links?Sent from my SM-G960U1 using Tapatalk Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 7, 2021 Share Posted September 7, 2021 9 hours ago, knever3 said: Links? Sent from my SM-G960U1 using Tapatalk LMGTFY: https://www.steeringcolumnservices.com/steering-column-parts/gm-buick-cadillac-chevrolet-oldsmobile-pontiac.php Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted September 8, 2021 Share Posted September 8, 2021 Ghetdjc, I can't use that website. WAY too much pink . . . Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 8, 2021 Share Posted September 8, 2021 7 minutes ago, JustEmptyEveryPocket said: Ghetdjc, I can't use that website. WAY too much pink . . . Lol, it’s a bit if an odd site but I have gotten some hard to find steering column parts from them years ago. They’ve been around a while it seems. Link to comment Share on other sites More sharing options...
knever3 Posted September 10, 2021 Author Share Posted September 10, 2021 I decided to give the "Pink Website" a call to go over some questions and make sure I was getting the correct parts. Yeah I could have saved money looking elsewhere online, but they had everything in stock and the guy knew what he was talking about walking around the warehouse. I can get behind a business like that. I decided to get a new tumbler and key set, went to ebay to get AMC keys to get cut though. Now I just will wait to see if my key in buzzer will work again. On a side note my lights on trigger to the buzzer doesn't work either. I have the blue box in the fuse box, but I think there is a wire missing with my conversion. We will see. Thanks for the recommendation guys! Link to comment Share on other sites More sharing options...
meagnificentwings Posted September 10, 2021 Share Posted September 10, 2021 Link to comment Share on other sites More sharing options...
