Joshua_A Posted August 26, 2021 Posted August 26, 2021 So I was an idiot and bought a Cps with the wrong plug Its the newer style 3 wire plug while I need the older 2 wire plug. any hope in switching them around or do I need to cut my losses
MiNi Beast Posted August 26, 2021 Posted August 26, 2021 I just cut the wires off and hard splice them together.. Or swap it out at parts store.
Joshua_A Posted August 26, 2021 Author Posted August 26, 2021 4 minutes ago, MiNi Beast said: I just cut the wires off and hard splice them together.. Or swap it out at parts store. Thats my thought, I would swap it out if I hadn't ordered from quadratic. They also decided that color coded wire is not necessary so I'm a little stuck in what to splice together.
MiNi Beast Posted August 26, 2021 Posted August 26, 2021 I just twisted them together untill it fired up and ran, then soldering them to ensure they 👍
Joshua_A Posted August 26, 2021 Author Posted August 26, 2021 1 minute ago, MiNi Beast said: I just twisted them together untill it fired up and ran, then soldering them to ensure they 👍 Welp might as well send it then ill update if anything blows up
omega_rugal Posted August 26, 2021 Posted August 26, 2021 find out which cable is A and B and splice them togehter, the other is just shielding
Joshua_A Posted August 27, 2021 Author Posted August 27, 2021 3 hours later and nothing I'm not having any luck with the wiring combination and so far can't get any signal from the damn sensor, I'm going to have to continue this tommorow however.
Eagle Posted August 27, 2021 Posted August 27, 2021 4 hours ago, Joshua_A said: 3 hours later and nothing I'm not having any luck with the wiring combination and so far can't get any signal from the damn sensor, I'm going to have to continue this tommorow however. You can't use a 91+ CPS in a Renix system. They operate on a completely different operating theory. Completely aside from the connector, they are not electonically compatible. You need to get a CPS for a 1986 thru 1990 Jeep. (AFAIK, the 4-cyl and 6-cyl Renix engines used the same CPS.)
cruiser54 Posted August 28, 2021 Posted August 28, 2021 On 8/26/2021 at 11:07 PM, Eagle said: You can't use a 91+ CPS in a Renix system. They operate on a completely different operating theory. Completely aside from the connector, they are not electonically compatible. You need to get a CPS for a 1986 thru 1990 Jeep. (AFAIK, the 4-cyl and 6-cyl Renix engines used the same CPS.) FINALLY!! The correct answer. I'm amazed at the amount of misinformation given to the OP before Eagle came along.
Joshua_A Posted August 28, 2021 Author Posted August 28, 2021 On 8/27/2021 at 12:07 AM, Eagle said: You can't use a 91+ CPS in a Renix system. They operate on a completely different operating theory. Completely aside from the connector, they are not electonically compatible. You need to get a CPS for a 1986 thru 1990 Jeep. (AFAIK, the 4-cyl and 6-cyl Renix engines used the same CPS.) Ah well should have seen that coming when I saw the extra wire, thanks. I guess I'll just fire the parts cannon once more and carry this one as a spare if I come across someone who needs it.
