Virginia Posted August 17, 2021 Posted August 17, 2021 I'm sure it's a clogged drain but I don't know how to clear it.
87MJTIM Posted August 17, 2021 Posted August 17, 2021 In the engine bay, to the right of the blower, is an outlet with a 90* tube. Remove the tube and clear any obstructions
Virginia Posted August 19, 2021 Author Posted August 19, 2021 I'll work on it after it stops raining.
ghetdjc320 Posted August 19, 2021 Posted August 19, 2021 3 hours ago, Virginia said: I'll work on it after it stops raining. If the tube is missing it will also leak back into the cab
Virginia Posted August 19, 2021 Author Posted August 19, 2021 6 hours ago, ghetdjc320 said: If the tube is missing it will also leak back into the cab Ok
cruiser54 Posted August 19, 2021 Posted August 19, 2021 Just squeeze the snake's cheeks and stay clear!!!
Virginia Posted August 19, 2021 Author Posted August 19, 2021 23 minutes ago, cruiser54 said: Just squeeze the snake's cheeks and stay clear!!! HA...funny but accurate. Thank you for the photo!
cruiser54 Posted August 19, 2021 Posted August 19, 2021 Getting it off is way easier than putting it back on as you can see. The squeeze trick has always worked for me.
Virginia Posted August 19, 2021 Author Posted August 19, 2021 On 8/19/2021 at 7:50 AM, cruiser54 said: Getting it off is way easier than putting it back on as you can see. The squeeze trick has always worked for me. I did the squeeze trick. Found the snake head but could not get clear. Flowed freely with clear water.
