Deleting my AC...need a renix pully/bracket solution
Anyone have an AC delete compressor bracket that they don't need?  Or, has anyone come up with an easy solution for fabbing one?  Mine's an 89 Renix 4.0, so there's none available on Amazon/eBay that I can find.  Availability is great for 91+, but of course Renix is tough to find.
Got one for sale?  Can work out a trade if you need a rear brake lens, maybe?  I may have other extra parts laying around too.
On 7/12/2021 at 8:01 PM, omega_rugal said:
mine came with no compressor
I'm not tracking you here.  Are you saying that yours came from the factory without a compressor?  If that's the case, then yours has a factory AC delete bracket with pulley.
If someone removed your compressor, then I'd like to know if they were able to route a shorter belt without adding a factory AC delete bracket.
22 minutes ago, Jesse J said:
I will trade you mine for your compressor mount
I purchased an AC delete pulley from jdog.  I I'll need my existing mount to install it in place of the compressor but I appreciate the offer.
8 hours ago, omega_rugal said:
this is it, the fan is backwards but i use a plastic fan mounted on the waterpump
So below is what I currently have going on.  With the compressor removed and a shorter belt installed in the way that you have yours, the fan will be rotating in the wrong direction.  I'd be interested in seeing a pic of your setup, especially of your waterpump-mounted fan.  I'd also like to know what belt you're running.
