Torq_Shep Posted July 8, 2021 Posted July 8, 2021 If someone has the orange one on this visor even with bad fabric behind it I am interested in at least one (maybe 2)
eaglescout526 Posted July 8, 2021 Posted July 8, 2021 I just found a visor with one of those. Fun fact: Those are SJ only stickers oddly enough. But I would suspect that some dealerships felt that they should put them in XJs and MJs which is nice of them to do but not all did that.
Pete M Posted July 8, 2021 Posted July 8, 2021 yeah, I would check with the fullsize Jeep groups. maybe someone makes new ones?
scaleless Posted July 9, 2021 Posted July 9, 2021 Probably won't look as good as the original, but simple decals like that can easily be reproduced by buying heat transfer vinyl and printing the lettering onto it with an inkjet printer. Something like this: https://www.amazon.com/dp/B0757XKQC3 vinyl sheets like this come in a lot of different thicknesses and don't always feed through all printers, but it's worth a try. You can also get them premade from here: https://www.stickeryou.com/products/iron-on-transfers but usually the ones made for T shirts are a lot thinner and more like the airbag warning than the thick orange vinyl.
Torq_Shep Posted July 9, 2021 Author Posted July 9, 2021 I may have found someone to make one however there will be a fee to have a new style generated. If anyone else is interested in a couple I might be able to work out a group buy with the person to help offset that fee.
MiNi Beast Posted July 10, 2021 Posted July 10, 2021 I think i have that sticker.. ill double check. .
Torq_Shep Posted July 10, 2021 Author Posted July 10, 2021 If anyone has one even if it is attached to your jeep, can I get dimensions to give to the artist?
MiNi Beast Posted July 11, 2021 Posted July 11, 2021 I did remember having a orange sticker. Forget the condition.
Torq_Shep Posted July 13, 2021 Author Posted July 13, 2021 From the artist. They gave me permission to post here. What SF number should we use? SF 8955014372 or SF 895500957. I am also going to ask to see if they can make a skinnier -
eaglescout526 Posted July 13, 2021 Posted July 13, 2021 I say the 9557 number. That’s earlier and will work with our MJs.
Torq_Shep Posted July 13, 2021 Author Posted July 13, 2021 9557 it shall be unless someone comes up with a better reason to use the other number.
