Torq_Shep Posted June 7, 2021 Share Posted June 7, 2021 Had an interesting failure today and I wanted to make sure it wasn't a fail safe thing that indicates a bigger problem before replacing the component and moving on. The comanche was at idle and I was working on the cooling fans. All the sudden I hear a pop and what sound like all of my refrigerant escaping. Well the pressure switch failed in a way where the refrigerant was leaking out of one of the prongs on the switch itself. Is this like a over pressure fail safe? AC was staying on steady with no apparent cycling so I do not think the system was over/under charged. Link to comment Share on other sites More sharing options...
Minuit Posted June 7, 2021 Share Posted June 7, 2021 99% this was just a failure of the switch, not any kind of safety precaution. If there was a safety in the system, it would be in the form of a binary high/low pressure switch that disables the A/C request signal, not as an explosive decompression. I've seen quite a few oil pressure sending units fail in exactly the way you describe. You should be OK with replacing the switch and recharging, but you will obviously want to watch the high side pressure as you do so. Since the refrigerant escaped so quickly, you will want to add oil as well. Link to comment Share on other sites More sharing options...
zomeizter Posted June 7, 2021 Share Posted June 7, 2021 Your cooling fans keep the high side pressure from becoming excessive. If you disabled the fans at some point with the A/C on, the pressure increased but your high pressure switch failed to disable the compressor clutch, then the gas found a way out through it... Link to comment Share on other sites More sharing options...
scaleless Posted June 7, 2021 Share Posted June 7, 2021 I agree - a simple failure of the switch. But as Zomeizter said, the switch was likely malfunctioning from the beginning and your high side pressure could very easily have exceeded a safe level. Hopefully it didn't cause any additional damage if so. Link to comment Share on other sites More sharing options...
Minuit Posted June 8, 2021 Share Posted June 8, 2021 I do not know if the pressure switch on these trucks had a high pressure cutoff feature but I'm leaning towards no. The FSM makes no mention whatsoever of a high cutoff pressure. Now for the later 94-96 systems, I've seen some literature that suggests the switch has a high cutoff at 475 psi. Like I said, be careful when recharging. Link to comment Share on other sites More sharing options...
Torq_Shep Posted June 8, 2021 Author Share Posted June 8, 2021 1 hour ago, Minuit said: I do not know if the pressure switch on these trucks had a high pressure cutoff feature but I'm leaning towards no. The FSM makes no mention whatsoever of a high cutoff pressure. Now for the later 94-96 systems, I've seen some literature that suggests the switch has a high cutoff at 475 psi. Like I said, be careful when recharging. I have a dual manifold for R134a and a vacuum pump. I will have to do some research on R134a as the last few systems I have done have been 410a (house AC and mini-split). Edit: I am not mixing 410a and 134a manifolds before anyone warns me =P Link to comment Share on other sites More sharing options...
Greentoy Posted June 26, 2021 Share Posted June 26, 2021 Hey guys I was just searching posts to see if anyone answered this before and I came across this thread. I need a low pressure switch for my 88 Comanche with 2.5. It has the dryer mounted switch. I went to all my local parts stores and they show a switch with male fittings on the switch. Mine is a male fitting on the dryer which means I need a female fitting on switch. Does anyone know the part number for the proper switch I need? Thanks in advance. Here is a pic of my dryer fitting (sorry for the poor focus). Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 26, 2021 Share Posted June 26, 2021 9 minutes ago, Greentoy said: Hey guys I was just searching posts to see if anyone answered this before and I came across this thread. I need a low pressure switch for my 88 Comanche with 2.5. It has the dryer mounted switch. I went to all my local parts stores and they show a switch with male fittings on the switch. Mine is a male fitting on the dryer which means I need a female fitting on switch. Does anyone know the part number for the proper switch I need? Thanks in advance. Here is a pic of my dryer fitting (sorry for the poor focus). When I installed my AC a couple years ago, that switch was a male end into the dryer. Both J3741260 and 04773763 have a male thread and prongs. Either you have the wrong dryer or the old one broke in a weird fashion. Is there any part numbers or numbers of any kind on your old switch? Link to comment Share on other sites More sharing options...
Greentoy Posted June 26, 2021 Share Posted June 26, 2021 My old switch is missing. PO pulled all a/c stuff. That picture is the dryer I ordered from Rock auto for the system. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
