Kjell Posted September 25, 2021 Share Posted September 25, 2021 https://www.facebook.com/buszkowo4x4 Link to comment Share on other sites More sharing options...
EagleEar Posted November 28, 2021 Author Share Posted November 28, 2021 Hello, I just sending some photos from restoration of 2,5 liter blue one , in black some body works are performed at the moment i will back soon with some update here. Black originally was white, so I would like to remove this raptor like layer and put real white raptor on it. Blue will stay blue , beside originally was black I will back soon with more photos. BTW, there is a lot of connectors under the dash which were not connected and seems there is no place where i can connect them. Does MJ electrical installation is the same no matter of version ? Can somebody could help with wiring or electrical manual ? Link to comment Share on other sites More sharing options...
fiatslug87 Posted November 28, 2021 Share Posted November 28, 2021 You can download manuals from this thread. Link to comment Share on other sites More sharing options...
EagleEar Posted November 28, 2021 Author Share Posted November 28, 2021 Wow, what a source of info, thanks !!!! Link to comment Share on other sites More sharing options...
EagleEar Posted December 10, 2021 Author Share Posted December 10, 2021 Hi, Some next steps , rear part of frame is protected now. I used epoxy paint for ships paining so frame is well secured. Link to comment Share on other sites More sharing options...
EagleEar Posted January 21, 2022 Author Share Posted January 21, 2022 Hello, More photos from latest work on MJ: Link to comment Share on other sites More sharing options...
EagleEar Posted September 8, 2022 Author Share Posted September 8, 2022 Hi Guys, Car is still during painting so I can't show you results yet, but i have problem with rear differential. It seems that driver side axle is little bent , wheel is directed into inside. I planned to change it using xj one but it seems that leaf spring in Mj is mounted down and Xj Up. No Comanche parts are available here , please advise how to solve it in best way. Link to comment Share on other sites More sharing options...
JYau Posted September 8, 2022 Share Posted September 8, 2022 You can cut the spring perches off and move them to the bottom, or buy a spring perch set. I'm sure you could find a new generic set that could work. You should also be able to re-use the spring plates as well. Link to comment Share on other sites More sharing options...
EagleEar Posted September 8, 2022 Author Share Posted September 8, 2022 Thanks for hint , it's seems workable. I will remove wheels check what is really going , one local offroad shop are making service of such repair i will also go with axle there I check what is possible. I also heard that there are some differences with mounts axle - wheel between XJ and MJ. Link to comment Share on other sites More sharing options...
Pete M Posted September 8, 2022 Share Posted September 8, 2022 yup, perch moving is very common. just remember that XJ perches and MJ perches are different widths apart too. don't just weld new ones directly under the XJ ones. MJs are 42" center to center. Link to comment Share on other sites More sharing options...
