EagleEar
EagleEar's Achievements
Comanche Fan (3/11)
questions about my new-to-me MJ in Poland
EagleEar replied to EagleEar's topic in MJ Tech: Modification and Repairs
Thanks for hint , it's seems workable. I will remove wheels check what is really going , one local offroad shop are making service of such repair i will also go with axle there I check what is possible. I also heard that there are some differences with mounts axle - wheel between XJ and MJ. -
Hi Guys, Car is still during painting so I can't show you results yet, but i have problem with rear differential. It seems that driver side axle is little bent , wheel is directed into inside. I planned to change it using xj one but it seems that leaf spring in Mj is mounted down and Xj Up. No Comanche parts are available here , please advise how to solve it in best way. -
Dash connectors - please help
Wow , thanks for quick help , it's amazing. I will buy this delay module for lamps and where is located emission timer ? What about number 3 ? I think there is no similar on other side so this is not speaker . -
Dear Jason, Many thanks for your help , the car is 88 , 2,5 liter , manual. I got 3 of MJ so even signature will not help No 8 was lying on the floor in the middle of cabin. -
1 - Transmission switch Power - will it work on manual ? 5 - instrument planel 6 - cargo light 7 - clock switch Please help with others. -
Hi, Some next steps , rear part of frame is protected now. I used epoxy paint for ships paining so frame is well secured. -
Hello, During replacing the dash i found a few connectors which are not used, please help me with identification of it . Thanks in advance !!! 1. 2. 3. 4. 5 6 7 8
Wow, what a source of info, thanks !!!! -
Hello, I just sending some photos from restoration of 2,5 liter blue one , in black some body works are performed at the moment i will back soon with some update here. Black originally was white, so I would like to remove this raptor like layer and put real white raptor on it. Blue will stay blue , beside originally was black I will back soon with more photos. BTW, there is a lot of connectors under the dash which were not connected and seems there is no place where i can connect them. Does MJ electrical installation is the same no matter of version ? Can somebody could help with wiring or electrical manual ? -
Hi , Old topic but i got some update here which might be helpful for others : Meat and Doria 76972 dimensions : Diameter : 43 mm Intake diameter : 12 mm Intake part length : 23 mm Overall length of metal body with intake : 135 mm JEEP: 52017698, JEEP: 8933063591, BOSCH: 9580810019, FISPA: 20493, FISPA: 70493, HOFFER: 7506972, MEAT & DORIA: 76972, SIDAT: 70493 Oem 2,5 liter pump no. 8933 002 251, model no. 5550: Diameter : 37 mm Intake diameter : 18-19 mm Intake part length : 24 mm metal body with intake : 110 mm In my case where I would like to install it to 2,5 engine is bigger than original one so modifications are necessary. Below I'm adding some photos how it looks like.
Hello , I was out of MJ rebuild because job issues , now I'm coming back and I hope soon I could show you further steps. Please advise if there are available some repair kits / panels to short bed ? Maybe cherokee XJ parts after some modification could be helpful : -
The problem is that guys who are selling car parts are cutting the hinges and not bother to remove the pin and save them. That's why you can find door but not with hinges. -
Hi, It looks that second MJ is comming tommorow a black one, i bought pair of front doors but without hinges. I can't find them here, is there a chance to use from different models or to buy somewhere? -
I have just checked this on youtube , I see that tape for a first time and you are right it will work. Please check the shipment to Poland of driver side lamp and write me on priv with details for payment.
