1J7FJ26S4NL113240
TeXJ_Gump
1992 MJ 4x4 Shortbed
^^Pictures in Link^^
Just picked up this 1992 MJ 4x4 shortbed with the 4.0 liter. Runs and drives. Needs a little love. I believe its got the AW4, np231, HPd30 and d35.
It's got zero body damage aside from a few dents in the tailgate. No Rust aside from 1 quarter sized blister in the front fenderwell, a 2in long line in the pinch weld on the lower lip of the tailgate and the driver seat bracket. It's a 1 owner truck out of Louisiana that was towed behind an RV most of its life. It will be getting restored and live with me in North Texas.
*C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT
-SA Charcoal
164 Zone 64-Memphis
1AA U.S. Dealer Retail
26C Customer Preferred Package 26C
2TC Customer Preferred Package 2TC
3VN Customer Preferred Discount
ALA
APA Monotone Paint
BAR 90 Amp Alternator
BCD 500 Amp Maintenance Free Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHN Command-Trac Part Time 4WD System
DHT Shift-on-the-Fly,P/Time T/Case
DJH 230MM Front Axle
DMD 3.55 Rear Axle Ratio
DRJ Dana 35 Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KER
KWR STRIPE/BADGE/MOLDING/COLOR
LBC Glove Box Lamp
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PE4 COLORADO RED CC PRI PNT - HE4
QE4 COLORADO RED CC SEC PNT - HE4
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Steering
SCG Leather Wrapped Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TBC Compact Spare Tire
TBM Tire Carrier Winch
TMW Tires
TZH Michelin Brand Tires
WJN 15" Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z82 Right Front Spring Group XI
Build date 8/14/91
Body code JL61
Sold by TWIN CITY JEEP-EAGLE, MONROE LA
-SA Charcoal
164 Zone 64-Memphis
ALA SE Decor Group
APA Monotone Paint
DHT Elec,Shift-on-the-Fly,P/Time T/Case
DRJ Dana M235 Wide Rear Axle
JJA Cigar Lighter
KER
LBC Glove Box Lamp
MBJ Black Powder Coated Front Bumper
MFF Black Grille
MMG Belt Moldings
RCD 4 Speakers
SBA Power Rack and Pinion Steering
TMW P265/60r18 BSW A/S All Terrain Tires
XBS Pickup Box
Build date 8/14/91
Body code JL61
Thank you!
Question: at the top of the list it says SA: charcoal.
Is that in reference to the factory paint color? Or something else?
8 hours ago, TeXJ_Gump said:
Ahh... makes sense. And the dana 235 wide track Rear axle... thats just a d35? Or is that some oddball that didn't get put in many XJ/MJs?
I went through and edited out the common mistakes and reused codes :L:  the 235 wide track refers to an axle that came in a more modern Jeep.
replaced the trans lines, serp belt, IAC,  removed the crusty decals, did an oil change, checked the diffs *will open/clean and refill with new fluid soon*, ordered new window trim, new trans mount and engine mounts. Will get plugs and swap in a good set of coils I have, also need to order a new fuel sending unit. Mine leaks when full on a hill and upon inspection had epoxy or jbweld around the inlet pipe. The power steering bracket bolts are kinda jacked. I had to shave off a quarter inch if bolt on the back one and the top one on the front had snapped in the bracket. Someone had overtightened it and stripped the threads. As a temp solution I used Teflon tape to fill the void. And I sawed off a quarter inch on the backside bolt which was not even close to in, but bottomed out. I'm assuming someone used the wrong bolt upon reinstall after a repair.
will update more as I have progress.
-SA Charcoal
164 Zone 64-Memphis
ALA SE Decor Group
APA Monotone Paint
JJA Cigar Lighter
KER
LBC Glove Box Lamp
MFF Black Grille
MMG Belt Moldings
RCD 4 Speakers
XBS Pickup Box
Build date 8/14/91
Body code JL61
Thank you!
Thank you!
Welcome and the charcoal is the interior color. The paint code starts with a P and Q towards the bottom of the list
