TeXJ_Gump
TeXJ_Gump's Achievements
  1. Yes. Looking for possibly 2 now. Maybe just 1 at a time. I'll have to see how serious my brother is.
  2. replaced the trans lines, serp belt, IAC, removed the crusty decals, did an oil change, checked the diffs *will open/clean and refill with new fluid soon*, ordered new window trim, new trans mount and engine mounts. Will get plugs and swap in a good set of coils I have, also need to order a new fuel sending unit. Mine leaks when full on a hill and upon inspection had epoxy or jbweld around the inlet pipe. The power steering bracket bolts are kinda jacked. I had to shave off a quarter inch if bolt on the back one and the top one on the front had snapped in the bracket. Someone had overtightened it and stripped the threads. As a temp solution I used Teflon tape to fill the void. And I sawed off a quarter inch on the backside bolt which was not even close to in, but bottomed out. I'm assuming someone used the wrong bolt upon reinstall after a repair. will update more as I have progress. Thank you! Question: at the top of the list it says SA: charcoal. Is that in reference to the factory paint color? Or something else?
  3. Frank, are you still making visors?? Really looking for 2 or 3.
  4. TeXJ_Gump
    Texans?
    Hey, I'm in Denton area! You still around and in the MJ gang?
  5. Ahh... makes sense. And the dana 235 wide track Rear axle... thats just a d35? Or is that some oddball that didn't get put in many XJ/MJs?
  6. Thank you! Question: at the top of the list it says SA: charcoal. Is that in reference to the factory paint color? Or something else?
  7. Thanks! It will be soon! It's a super clean base for a tasteful build/full resto
  8. 1992 MJ 4x4 Shortbed ^^Pictures in Link^^ Just picked up this 1992 MJ 4x4 shortbed with the 4.0 liter. Runs and drives. Needs a little love. I believe its got the AW4, np231, HPd30 and d35. It's got zero body damage aside from a few dents in the tailgate. No Rust aside from 1 quarter sized blister in the front fenderwell, a 2in long line in the pinch weld on the lower lip of the tailgate and the driver seat bracket. It's a 1 owner truck out of Louisiana that was towed behind an RV most of its life. It will be getting restored and live with me in North Texas.
