MJ20 Posted November 10, 2007 Share Posted November 10, 2007 I found an 87 cherokee pioneer tilt-column, no cruise, auto w/ floor-shifter an wondered if there are problems putting it in my 89. I wanted to get an 89 to avoid problems but so far not one found. Should I just wait it out for an 89 or 90 to come along? Link to comment Share on other sites More sharing options...
Geonovast Posted November 10, 2007 Share Posted November 10, 2007 Should go right in, as long as you don't have an auto column shifter Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 10, 2007 Share Posted November 10, 2007 identical as long as you have a floor shifter as well. Link to comment Share on other sites More sharing options...
LocoJeeper Posted November 10, 2007 Share Posted November 10, 2007 I found out from pulling an XJ column to put in my MJ that if you go from a column shifting MJ your going to need a longer AT shifter cable... and (optionally... some would say required) a shift interlock cable. Link to comment Share on other sites More sharing options...
MJ20 Posted November 10, 2007 Author Share Posted November 10, 2007 That sounds great. I already have a gauge cluster and cruise control out of an 89 laredo. Once I get a tilt-column I can swap everything at one time. Would that 89 cruise/wiper arm fit this column? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 10, 2007 Share Posted November 10, 2007 yep Link to comment Share on other sites More sharing options...
MJ20 Posted November 11, 2007 Author Share Posted November 11, 2007 Thanks guys. It turns out this one doesn't have a key and since it’s not the color I want I’m going to keep searching. Link to comment Share on other sites More sharing options...
jtdesigns Posted November 11, 2007 Share Posted November 11, 2007 what color r u looking for?? Link to comment Share on other sites More sharing options...
MJ20 Posted November 12, 2007 Author Share Posted November 12, 2007 Black with the black jeep steering wheel. I haven't found a black one in southern az yet. This last one showed up in a parts xj and it's blue so I was kinda interested. There's some on ebay too but usually without the steering wheel and usually not black. Link to comment Share on other sites More sharing options...
Geonovast Posted November 12, 2007 Share Posted November 12, 2007 If you find a column without a steering wheel...I have one that has the whole piece in front instead of just the cap..black. Link to comment Share on other sites More sharing options...
jtdesigns Posted November 12, 2007 Share Posted November 12, 2007 Black with the black jeep steering wheel. I haven't found a black one in southern az yet. This last one showed up in a parts xj and it's blue so I was kinda interested. There's some on ebay too but usually without the steering wheel and usually not black. I have a red column in my mj that tilts, but it needs to be gray. I was thinking of just painting the red one, because of the price involved in buying one. Link to comment Share on other sites More sharing options...
MJ20 Posted November 12, 2007 Author Share Posted November 12, 2007 I have a red column in my mj that tilts, but it needs to be gray. I was thinking of just painting the red one, because of the price involved in buying one. There’s a gray one on ebay if you’re interested. http://cgi.ebay.com/ebaymotors/87-94-Je ... otohosting Link to comment Share on other sites More sharing options...
MJ20 Posted November 27, 2007 Author Share Posted November 27, 2007 Hey guys, I gave up on finding a local tilt column so I scored a tilt column w/cruise and delay wipers from ebay for an 86-94 cherokee. I wonder if there’s some way to verify it’s the correct one for an xj/mj and not for an fsj. Maybe by looking at the pics or by an oal. I don’t have access to another column out of a jeep but looking at my 91 xj it’s similar. A few things I noticed about this column are there’s no finger lever for removing the key. It has a cable on top to activate something. It has an american motors red part # tag on the column. Overall it’s in good shape. The key comes out of the ignition in any position just like all my other jeeps have done lol. Now I am wondering if I should use the rod activated switches already on this column or replace them with the switches on my original non-tilt column. Link to comment Share on other sites More sharing options...
LocoJeeper Posted November 27, 2007 Share Posted November 27, 2007 Appears to be an XJ/MJ column... and not from a FSJ. Good thing you got the AT shift interlock cable still attached. I pulled my donor column from a manual equipped XJ... and don't have the interlock capability. If I feel like doing it.. in the spring when I hit the j/y again I might pull another one. Link to comment Share on other sites More sharing options...
Eagle Posted November 27, 2007 Share Posted November 27, 2007 The little lever to release the key is used only on the manual transmissions. On the XJs with automatic (and the MJs with floor shift) that function is handled by putting the floor shifter into Park. Finding a column with no key is not a reason to run away. If you got it with a key, most likely it would only have ONE key, and the key would be so badly worn that you could never get a good copy made from it anyway. Pep Boys and the other parts houses sell replacement lock cylinders for about $10 (maybe a bit more now, I bought mine a few years ago) and it's a fairly easy job to install. Much easier with the column out of the vehicle. Link to comment Share on other sites More sharing options...
MJ20 Posted November 27, 2007 Author Share Posted November 27, 2007 I figured that cable had something to do with an auto. I couldn’t see one attached to my xj column which has an ax15. I’ll have to find the exploded view of the column in the fsm and see how it comes apart. I hope there’s not an inspection problem for not having the key lever feature. Getting close, only three more parts needed (I think) to do the whole gauge cluster/cruise control/tilt column swap. Link to comment Share on other sites More sharing options...
LocoJeeper Posted November 27, 2007 Share Posted November 27, 2007 I figured that cable had something to do with an auto. I couldn’t see one attached to my xj column which has an ax15. I’ll have to find the exploded view of the column in the fsm and see how it comes apart. If I remember correctly, the column has two bolts going through a plate... the holds the interlock cable in place. From there is just a ball in socket type fitting. Link to comment Share on other sites More sharing options...
comanche87 Posted March 21, 2008 Share Posted March 21, 2008 i got a question bout the tilt columns. i got one and I'm trying to figure out how to change the ignition lock. i want to use my keys instead of the only one it came with. is there a way to do that its an 87 mj puttin in a 88 xj tilt. Link to comment Share on other sites More sharing options...
Wildman Posted March 21, 2008 Share Posted March 21, 2008 i got a question bout the tilt columns. i got one and I'm trying to figure out how to change the ignition lock. i want to use my keys instead of the only one it came with. is there a way to do that its an 87 mj puttin in a 88 xj tilt. Go here, and down about 15 articles down is the PDF file for the ignition lock. http://www.lunghd.com/Downloads_and_Links/Downloads.htm Link to comment Share on other sites More sharing options...
comanche87 Posted March 21, 2008 Share Posted March 21, 2008 thanks alot Link to comment Share on other sites More sharing options...
