jeep 89 87 front window
Depending on where your at and if you shop around yeah,  safelite in my area is 250 for the windshield but they are usually a little higher then some of the other places around me.
also realize with used most shops don't like to install and won't warranty it if it breaks. There is a possibilty of breakage just removing it as well as they are glued in.
51 minutes ago, Pete M said:
all years of MJ/XJ use the same windshield glass. :L:  bonus points if you get the 97+ rubber trim (the glass itself still glues in, the rubber trim just replaces the metal trim)
They switched over to rubber trim in 1994 or maybe even a bit earlier than that I believe.
