Iv got an 86 with a 2.5 and for some reason it dies every time the alternator starts charging the battery. The alternator is good and iv replaced about everything possible related to it and checked all grounds I can find.  Running a wire to the battery it kills the engine. The only way I can drive it is with a solar panel keeping the battery charged. What could possibly be the issue?
Can you keep the truck going long enough to get a multimeter to the battery to see if it’s outputting? I’m almost wondering if something in between the battery and the alt is bad.
without the solar panel.
What happens if......You get it running.....you remove a battery cable from the battery......does it continue to run or die?
It will be fine
and it will tell you right away if the problem is the battery or the alt.....no guessing
I don't understand "it dies every time the alternator starts charging the battery".  Your alternator is charging from the  moment the engine starts.  When you start the engine, how long does it run before it dies?  What makes you think the alternator started charging and stalled the engine?
Also, what does "Running a wire to the battery it kills the engine." mean? Are you saying that you have to disconnect the alternator before you can start the engine?
It has a gm single wire alternator and it will start with the power wire to the alternator connected but dies in 10 seconds or less. Alternator charges at 14.5 volts
