Any Chevy 350 gurus out there?
SoCalManche
I've got a friend who just snagged a 1986 Chevy K10 Suburban 5.7l carbureted V8. We've been tinkering on it a bit, and it's been a blast. However, we have uncovered this sensor in the thermostat housing that seems to be single-pin and it's housing broken on the sensor itself.
With all our scouring across the web, we are unable to find a single prong sensor, to which we are assuming a temp sensor or sender of some kind.
Help!
It's a temperature sender.  It should ground to the thermostat housing into the engine.
Hook up an ohm meter between the pin and the housing.  It should have a resistance that changes with heat.  Or if it's an idiot light sender, it will switch on/off when you hit the right temp.
27 minutes ago, ghetdjc320 said:
Did the sensor run a light or gauge?
The instrument cluster does have a temperature gauge.
Yeah, there is a temperature gauge; no idiot light. But we are unable to find a single terminal sender/sensor/switch, and we don't have full reference since this one looks broken.
15 hours ago, youngfred said:
Check out :
https://www.classicindustries.com/shop/1987/chevrolet/truck/parts/?q=Temp Sending Unit .
How many pins on the black sending unit connector, in the red circle?
youngfred
15 hours ago, derf said:
Could be the wrong part for the vehicle.  Could also be that one of the two terminals broke off.  It's hard to see in the picture.
Just a single terminal. Here are a couple close ups. But definitely a possibility this is the wrong component because the closest looking temp sender we have found to resemble what this is, is from a '67 Nova.
