How to trick a 1997 automatic
Just take the CEL bulb out and you'll never know!  Only proper fix is to swap the PCM, not really a way to trick it to think the trans is there and working unless you were an electrical engineer and came up with some circuitry to do it.
A YJ pcm won’t work in a 97+ XJ.
ecus can be reflashed to a different PN in some cases. I had a customer in France needing a non security pcm for a 97xj, so we had a federal ECU reflashed to the California/export PN and to match his vin.
