10thta Posted February 8, 2021 Posted February 8, 2021 1989 Comanche Pioneer shortbed 177K miles 4.0/auto on column/2wd build date (unk) Houston, TX, just bought, been in TX since new RED w lt tan interior, bench seat oddities: bedliner, fiberglass bed cover, plan on restoring to orig- its all there can anyone run the VIN and trim tags or direct me to where I can find a trim tag decoder? this is my 4th jeep, but first MJ (yay!)
eaglescout526 Posted February 8, 2021 Posted February 8, 2021 *E1 Cloth Bench Seat -YY 162 Zone 62-Houston 1AA U.S. Dealer Retail 5AM Largo Tracking 5KM AMES Department Stores ALM APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ Dana 35 Wide Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K2X STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KKF LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 9/27/88 Body code TM61 Sold by PAGAN-LEWIS MOTORS INC, CORPUS CHRISTI TX
Pete M Posted February 9, 2021 Posted February 9, 2021 4 hours ago, 10thta said: 1989 Comanche Pioneer shortbed 177K miles 4.0/auto on column/2wd build date (unk) Houston, TX, just bought, been in TX since new RED w lt tan interior, bench seat oddities: bedliner, fiberglass bed cover, plan on restoring to orig- its all there can anyone run the VIN and trim tags or direct me to where I can find a trim tag decoder? this is my 4th jeep, but first MJ (yay!) if you're new to MJs, this is the thread I suggest reading first
10thta Posted February 9, 2021 Author Posted February 9, 2021 Only pic so far as purchased...dirty, wrong wheels, and wrong mirrors...for now. Thanks for running those codes.
fiatslug87 Posted February 9, 2021 Posted February 9, 2021 @10thta or @Pete M or @eaglescout526 please change the title to just the VIN
