Aw4 shifting/slipping problems
5 hours ago, Joshua_A said:
the 94 uses an electronic speedo and honestly I tried to trace the harness back and it was nearly impossible so I decided to stick with the older style speedo cabled 87. That and less miles on the old one
That's a non-issue. Just remove the electronic speedo sender from the '95 transfer case. You'll remove the sender from your transfer case before youu pull the tranny and transfer case. Install the 5-speed, then put the speedo cable right into the same place on the "new" transfer case. Just be sure to make note of the orientation of the sender in your truck before you remove it, and be sure to install it with the same orientation.
