Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 1 minute ago, Southpaw said: ludington center of the state rite on lake mi.. north of muskegon and g,r Link to comment Share on other sites More sharing options...
Pete M Posted January 27, 2021 Share Posted January 27, 2021 what's up with your engine? Link to comment Share on other sites More sharing options...
Southpaw Posted January 28, 2021 Author Share Posted January 28, 2021 3 hours ago, Pete M said: what's up with your engine? guy pulled head off and left it sit for 8 years Link to comment Share on other sites More sharing options...
Pete M Posted January 28, 2021 Share Posted January 28, 2021 oh. well, that'll do it. shouldn't be hard to find a used engine if you're in a hurry. Link to comment Share on other sites More sharing options...
Southpaw Posted January 28, 2021 Author Share Posted January 28, 2021 4 minutes ago, Pete M said: oh. well, that'll do it. shouldn't be hard to find a used engine if you're in a hurry. getting this one rebuilt i didnt want to spend that kind of money but hopefully it will be worth it Link to comment Share on other sites More sharing options...
Pete M Posted January 28, 2021 Share Posted January 28, 2021 they are super tough engines. as long as the rebuilder is competent, you should be golden Link to comment Share on other sites More sharing options...
Southpaw Posted January 28, 2021 Author Share Posted January 28, 2021 13 hours ago, Pete M said: they are super tough engines. as long as the rebuilder is competent, you should be golden 13 hours ago, Pete M said: they are super tough engines. as long as the rebuilder is competent, you should be golden accurite engines in G.R what about tranny automatic they pretty durable also thanks for info Link to comment Share on other sites More sharing options...
Pete M Posted January 28, 2021 Share Posted January 28, 2021 the AW4 is one of the best automatics ever made. Link to comment Share on other sites More sharing options...
89 MJ Posted January 28, 2021 Share Posted January 28, 2021 I rarely hear of people having AW-4 issues. The only reason that most people pull it out is to swap in an AX-15. Link to comment Share on other sites More sharing options...
Jesse J Posted January 28, 2021 Share Posted January 28, 2021 2 hours ago, 89 MJ said: I rarely hear of people having AW-4 issues. The only reason that most people pull it out is to swap in an AX-15. couldnt be be I am kinda regretting not picking that thing. rebuild though it's gonna happen. come to think of it idk if i could still use my tranny cooler on it Link to comment Share on other sites More sharing options...
ghetdjc320 Posted January 28, 2021 Share Posted January 28, 2021 4 hours ago, 89 MJ said: I rarely hear of people having AW-4 issues. The only reason that most people pull it out is to swap in an AX-15. Same here. Quite a bulletproof tranny. Link to comment Share on other sites More sharing options...
Southpaw Posted January 28, 2021 Author Share Posted January 28, 2021 29 minutes ago, ghetdjc320 said: Same here. Quite a bulletproof tranny. thanks i think i will just replace front and rear seals see how it works out Link to comment Share on other sites More sharing options...
ghetdjc320 Posted January 28, 2021 Share Posted January 28, 2021 1 hour ago, Southpaw said: thanks i think i will just replace front and rear seals see how it works out I run an aftermarket moroso tranny cooler and am going to install the transgo shift kit soon in mine but that tranny has never slipped, failed to shift or acted up at all. And I’ve pulled some serious weight with my MJ. I just keep it out of overdrive if towing and keep the fluids and filter fresh. Not to keen on the shifting points as it’s always wanting to downshift ahead of schedule on me but the transgo kit will take care of that. Link to comment Share on other sites More sharing options...
