Medicwithamanche Posted January 19, 2021 Share Posted January 19, 2021 Buying this tomorrow morning from a buddy. Figured I’d add it to the registry. It was his buddies that passed away a few years ago and it sat in a yard for about 5 years. 88 Eliminator 4.0 5-speed 2wd needs fixing as of now 1/18/21: -steering column needs replaced -no headlights or taillights work with the switch but has brake lights. -general tune up -new tires -washdown. I plan on leaving this one stock and make it a cool little farm truck. Link to comment Share on other sites More sharing options...
89 MJ Posted January 19, 2021 Share Posted January 19, 2021 Looks like it will be a great truck! Link to comment Share on other sites More sharing options...
Torq_Shep Posted January 19, 2021 Share Posted January 19, 2021 I have a 2wd AX-15 in San Antonio if you decide you want to ditch the BA-10 Looks a lot like my black truck. Super lucky you still have the eliminator wheels on that thing! Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 20, 2021 Share Posted January 20, 2021 I will never understand the various shades of grey for our interiors. 1JTMW6451JT021382. VINs always have 1's. Never I's. *Q7 Seat - Cloth Low-Back Bucket -SA Charcoal 3LY AGD Pro-AM Edition Group APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CAC BUCKET SEAT - LO BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DDJ 5SPD MANUAL TRANS ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS LNJ DUAL ROAD LAMPS - FRONT MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ Transmission Heater PS4 BRIGHT PLATINUM METALLIC CLEAR COAT QS4 BRIGHT PLATINUM CLEAR COAT RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT WJH 15X7 Aluminum Wheels YJP NEW VEHICLE SERVICE - WINDSOR Build date 8/11/87 Body code TS61 Link to comment Share on other sites More sharing options...
89 MJ Posted January 20, 2021 Share Posted January 20, 2021 It seems like an early 88 Link to comment Share on other sites More sharing options...
Pete M Posted January 20, 2021 Share Posted January 20, 2021 On 1/19/2021 at 2:13 AM, Medicwithamanche said: Buying this tomorrow morning from a buddy. Figured I’d add it to the registry. It was his buddies that passed away a few years ago and it sat in a yard for about 5 years. 88 Eliminator 4.0 5-speed 2wd needs fixing as of now 1/18/21: -steering column needs replaced -no headlights or taillights work with the switch but has brake lights. -general tune up -new tires -washdown. I plan on leaving this one stock and make it a cool little farm truck. a very early 88! if it's not the first Eliminator, it'd be dang close. anyone find one that's older? Link to comment Share on other sites More sharing options...
Medicwithamanche Posted February 19, 2021 Author Share Posted February 19, 2021 Alright. Little update on the build. Had to replace the steering column cause the tilt steering knuckle had broken. Found I’m not getting my power to my fuse panel and the engine harness has some splices and rats have chewed on most lines. I’m thinking fusible links are bad. Probably just gonna replace it from a parts rig. Bought all the stuff for a tune up but I need to get it turning over first. The new column is giving me troubles. I can’t turn the key back to “Off” so the little release arm may be stuck or my ignition tumbler needs replacing. Another project and more problems yay!! So much for a quick fix and daily it. Link to comment Share on other sites More sharing options...
Pete M Posted February 19, 2021 Share Posted February 19, 2021 1 hour ago, Medicwithamanche said: Alright. Little update on the build. Had to replace the steering column cause the tilt steering knuckle had broken. Found I’m not getting my power to my fuse panel and the engine harness has some splices and rats have chewed on most lines. I’m thinking fusible links are bad. Probably just gonna replace it from a parts rig. Bought all the stuff for a tune up but I need to get it turning over first. The new column is giving me troubles. I can’t turn the key back to “Off” so the little release arm may be stuck or my ignition tumbler needs replacing. Another project and more problems yay!! So much for a quick fix and daily it. you should start a build thread in the projects subforum. not many are going to read the registry and keep up on your work. Link to comment Share on other sites More sharing options...
Medicwithamanche Posted February 19, 2021 Author Share Posted February 19, 2021 18 hours ago, Pete M said: you should start a build thread in the projects subforum. not many are going to read the registry and keep up on your work. True. I should! Link to comment Share on other sites More sharing options...
jdog Posted March 16, 2021 Share Posted March 16, 2021 Selling Dealer: MIKE SMITH AUTOPLAZA INC Beaumont, TX Link to comment Share on other sites More sharing options...
Medicwithamanche Posted May 10, 2021 Author Share Posted May 10, 2021 Selling this one now. Located in East Texas. Asking $1600. As if this posting it’s available. Link to comment Share on other sites More sharing options...
