Rusty Jeep Posted May 7, 2021 Author Share Posted May 7, 2021 I'm just wondering what will work. I can't find a clear answer anywhere. Link to comment Share on other sites More sharing options...
81Chero Posted July 19, 2021 Share Posted July 19, 2021 Have you got the engine in yet? or even gotten into the wiring?? I've got a '93 XJ. 2wd, 2dr, 4cyl/5spd, 8.25(4.1) that i've already got the novak mounts and 350 sitting in and T-5, 5spd. (just have to swap the tail to a S-10 mid-shifter to get it in the right position) Doesn't look all that bad or complicated, or "expensive" at all, and really don't know how different the engine compartment and wiring is to a MJ? I'm staying 2wd. So, driveshaft and make a angled trans mount. I had a 88 and EVERYTHING looked the same from what I remembered. (it's gone a while ago) I've got several projects going on and have you looked at the AR-5 from a Colorado, Canyon? I'm going to get out in the shop and see if the bellhousing swaps over to the NV3550 (removable bellhousing from a Dakota) I'm using the 3550. But the bolt pattern to the trans body looks really close. The early and later 4.0 jeep bellhousing will swap to the 3550. But you have to decide if you want the internal or external slave. (not that expensive or big of a problem) Plus the bell bolts to the early AMC V8's!! Link to comment Share on other sites More sharing options...
