Radiator hose and hoses
Gonna have to cut them off. Replace with heater hose and a hose clamp. Buy by the foot at any auto parts store. I deleted the valve there and converted to an open cooling system just last week. Cut the hose fitting, not the pipe coming out the firewall. You're gonna need that.a34a9cf2d80922d1f77d208ea6d67e89.jpg
89 Comanche
Eliminator
2wd
4.0L
5 speed PukeGoat
Factory Original
Those are factory on the 4.0 from what I have seen. Mine had those on it also. I used a grinder with a thin cut off disc. Just cut through the aluminum band and they will peel off. The hose to the pressure tank is special. Let me try to figure out where I got it.
