CGCWO Posted January 6, 2021 Posted January 6, 2021 I am in need to two header (86-92) header panels and one grill. Working on two trucks and will be keeping them with old style front ends.
schardein Posted January 7, 2021 Posted January 7, 2021 5 minutes ago, CGCWO said: I am in need to two header (86-92) header panels and one grill. Working on two trucks and will be keeping them with old style front ends. You know the header panel design changed in 91. 91 uses a one piece headlamp surround, while older header panels used a two piece headlamp surround. Also the grills were different, but I think those interchange. I can't remember the cross-compatibility of the headlamp surrounds, but it doesn't work one way- I believe you can't use the older two-piece style on the newer header. You may want to specify depending on what grill & headlamp surrounds you intend to use.
schardein Posted January 7, 2021 Posted January 7, 2021 Rockauto has the newer style for $32 + shipping. I can't speak to quality. I'd bet OEM is better. https://www.rockauto.com/en/catalog/jeep,1991,cherokee,4.0l+l6,1180055,body+&+lamp+assembly,header+panel,819
88mjsally Posted January 10, 2021 Posted January 10, 2021 I have one from a 93 xj (91-96 are the same) however shipping often costs as much as the header does if you’re far away from SC
jdog Posted January 10, 2021 Posted January 10, 2021 I've got two but shipping from Co to Florida would suck
Torq_Shep Posted January 11, 2021 Posted January 11, 2021 I have one with a small crack in the fiberglass but again TX to Florida...
CGCWO Posted January 15, 2021 Author Posted January 15, 2021 I am going to try and repair one that I have. Bought one of the repoduction ones from rock auto. Fit is not perfect but I think it will do for one of my trucks.
