X2 86-95 front header panels
CGCWO
5 minutes ago, CGCWO said:
I am in need to two header (86-92) header panels and one grill. Working on two trucks and will be keeping them with old style front ends.
You know the header panel design changed in 91.  91 uses a one piece headlamp surround, while older header panels used a two piece headlamp surround.  Also the grills were different, but I think those interchange.  I can't remember the cross-compatibility of the headlamp surrounds, but it doesn't work one way- I believe you can't use the older two-piece style on the newer header.
You may want to specify depending on what grill & headlamp surrounds you intend to use.
