Warren99 Posted December 19, 2020 Share Posted December 19, 2020 Real quick and easy question, does it matter if I get the front driveshaft off a automatic Cherokee (so np242 tc) and would it be the right length and bolt up to my np231? Link to comment Share on other sites More sharing options...
Pete M Posted December 19, 2020 Share Posted December 19, 2020 off the top of my head I think the driveshaft lengths are transmission dependent and not t-case dependent. Link to comment Share on other sites More sharing options...
Dzimm Posted December 19, 2020 Share Posted December 19, 2020 7 minutes ago, Pete M said: off the top of my head I think the driveshaft lengths are transmission dependent and not t-case dependent. I believe you are correct. I've never heard of the t-cases being different but haven't had a 242 to confirm. I believe there is a spline count change at some point in the production run so that may be a concern. As long as it's from a similar year it would probably match though. Link to comment Share on other sites More sharing options...
Warren99 Posted December 19, 2020 Author Share Posted December 19, 2020 Ok, my 231 is from a 92 YJ anyways so most cherokee driveshafts should work then. Link to comment Share on other sites More sharing options...
OldSch88L Posted December 20, 2020 Share Posted December 20, 2020 AX-5s and AX-15 transmissions measure roughly 16", while the AW-4 is roughly around 25". I know that 2.5 and 4.0 engine mounts are not at the same spot on the frame to compensate for the different engine lenghts. I doubt AMC would put yet again the mounts in different spots to compensate for different transmission lenght. So short answer: measure, measure, measure... I got a feeling that the AW-4 puts the t-case further back than a manual trans, hence making the shaft too long for your application... Link to comment Share on other sites More sharing options...
Tex06 Posted December 21, 2020 Share Posted December 21, 2020 22 hours ago, OldSch88L said: AX-5s and AX-15 transmissions measure roughly 16", while the AW-4 is roughly around 25". I know that 2.5 and 4.0 engine mounts are not at the same spot on the frame to compensate for the different engine lenghts. I doubt AMC would put yet again the mounts in different spots to compensate for different transmission lenght. So short answer: measure, measure, measure... I got a feeling that the AW-4 puts the t-case further back than a manual trans, hence making the shaft too long for your application... But, if it's too long, it can be shortened by a driveline shop pretty easily! Link to comment Share on other sites More sharing options...
