Devo88 Posted November 10, 2020 Posted November 10, 2020 1987 Jeep Comanche Base w/ 247550 miles I’ll try to add a pic later. 2.5L, 4 sp manual, 2wd, Dana 35, short bed Build Date: Unknown, not legible Location: Southwest Florida Stutus: Recent purchase, project awaiting work (although does run and drive) Color: medium blue metallic exterior, tan interior Floor shifter, bench seat, rubber floors, wood grain molding on dash and doors, rear sliding window, aluminum sport 5-spoke wheels. Current owner: Rich Stoj
eaglescout526 Posted November 10, 2020 Posted November 10, 2020 I love it when more 2.5L's show up. *X1 -YY APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS HCC HEATER W/UPR LEVEL VENTIL - TYPE II LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) PXF QXF TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 2/5/87 Body code TL61
Devo88 Posted November 10, 2020 Author Posted November 10, 2020 Wow, that was extremely fast, thank you eaglescout526 !
Pete M Posted November 10, 2020 Posted November 10, 2020 2 minutes ago, Devo88 said: Wow, that was extremely fast, thank you eaglescout526 ! bummer that your build printout was kinda small. a lot of info was lost before Chrysler started putting them into the computers and the list is more or less luck of the draw. but you still might have your original paper copy! typically it's found inside the drivers door, behind the rear carpet panel, wedged under the bench seat, or even up inside the pass side of the dash. no matter what though, you now know her birthday.
Devo88 Posted November 10, 2020 Author Posted November 10, 2020 9 minutes ago, Pete M said: but you still might have your original paper copy! typically it's found inside the drivers door, behind the rear carpet panel, wedged under the bench seat, or even up inside the pass side of the dash. no matter what though, you now know her birthday. I will absolutely be looking for that paper copy, I hope it exists! Much appreciate your info Pete.
89 MJ Posted November 10, 2020 Posted November 10, 2020 That's a good looking truck. It looks like a great truck to drive as-is.
jdog Posted January 31, 2021 Posted January 31, 2021 Selling Dealer: LINDER TRUCK CENTER INC Lakeland FL
