Dave Vig Posted November 4, 2020 Posted November 4, 2020 Ok so I need a rear differential yoke and a rear u joint. Hope this isn’t a dumb ? But rock auto had several choices. Do I need to no if my rear end is a Dana 44 ? Dana 35 or Chrysler 8.25? I believe I had what I have confirmed here that I have a Dana 44 (see pic attached). Can any one help as to what I need to get or are they all the same ?
Dave Vig Posted November 4, 2020 Author Posted November 4, 2020 Here is a few pics of the rear end of my Comanche
Dave Vig Posted November 4, 2020 Author Posted November 4, 2020 Pete did you see what I was asking about the rear differential yolk? And rear u joint?
Dave Vig Posted November 4, 2020 Author Posted November 4, 2020 So does the rear differential yolk need to be for the Dana 44 ? I’m assuming yes correct?
derf Posted November 4, 2020 Posted November 4, 2020 19 minutes ago, Dave Vig said: So does the rear differential yolk need to be for the Dana 44 ? I’m assuming yes correct? Yes. Dana 44. All rear axles used the same u-joint so just get one for the rear and you're good. I would recommend Spicer brand for both. You can get them from Rock Auto I believe. Decent price and as good or better (sometimes way better) than other options.
derf Posted November 4, 2020 Posted November 4, 2020 Links for Rock Auto parts. DANA 2480911X DANA 5153X
