Door Hinge
Torq_Shep
This one is staying relatively stock =P
With that being said I can fix the existing hinge its just going to have to be drilled out and sleeved and holes filled with weld as the PO of the PO of the PO or whoever kinda knackered it.
26 minutes ago, eaglescout526 said:
There are later style hinges available, they come as a kit from Chrysler. I have a kit, I would love to install it but have no experience with trying such yet but Chrysler recommends them in place of the older style.
Do you have the part number by chance?
Interesting. I ended up buying the team cherokee rears to see if they work. They were cheap enough that if they don't I am not out much. If they do work I will make a write-up or something.
Still interested in an OE front one for 84-96 if anyone has one kicking around.
3 minutes ago, ghetdjc320 said:
I didn’t see any of those in stock anywhere. Is that a current part number?
Most current part number. I have the kit actually sitting in my parts. I asked a while back if anyone had tried to install the newer style hinges and didnt get anywhere.
