GreenJeepGrump Posted October 23, 2020 Posted October 23, 2020 While not new to jeeps and this model year, I am new to the Comanche scene. I found a 89 4.0 AX15 long bed on Facebook the other day. Seems to be clean for my area. Has 190k miles. Trans and tcase were redone about 35k ago. Has brand new duratrac’s and a 4” lift. Needs a rocker panel, floorboard, and new paint is what I’ve noticed from the pictures. In y’all’s opinion, what’s it worth. The man is asking 2750. Thank you. Can’t add any pictures, the forum won’t let me.
Dzimm Posted October 23, 2020 Posted October 23, 2020 Yeah pretty fair price to start with assuming there are no hidden issues. Offer a little less and try to make a deal! You should be able to add pictures directly with the "add files" option in the reply box. You are limited on upload size so don't add too many at a time.
Pete M Posted October 23, 2020 Posted October 23, 2020 6 hours ago, GreenJeepGrump said: Can’t add any pictures, the forum won’t let me. there's nothing on place to prevent you from adding pics. just upload them straight from your phone/laptop. if you're having difficulty with multiple pics at once, try doing just one at a time.
GreenJeepGrump Posted October 23, 2020 Author Posted October 23, 2020 Got it, here’s some pictures of it. I offered him 2300. The floor doesn’t bother me, I’ve fixed that before. The doors got some rust starting, are they the same as a Cherokee?
89 MJ Posted October 23, 2020 Posted October 23, 2020 1 hour ago, GreenJeepGrump said: Got it, here’s some pictures of it. I offered him 2300. The floor doesn’t bother me, I’ve fixed that before. The doors got some rust starting, are they the same as a Cherokee? Pretty much everything doors forward is the same as a 4 door XJ. The floorpans are a little bit different, by XJ pans can be modified to fit pretty well. My build thread is in my signature and I did a driver side door, rocker, and floor if you have any questions. Be sure to check out the frame where the leaf spring bolts in in the front. That is a common place for rust.
Pete M Posted October 23, 2020 Posted October 23, 2020 for that much cash you can get a solid truck from down south or out west. but if you're just looking for a wheeler, it should work fine.
GreenJeepGrump Posted October 23, 2020 Author Posted October 23, 2020 Didn’t get it. Pictures tell a different story. There was a lot of spray foam soft work. Couldn’t get myself to pull the trigger on my new daily until I get a better one.
NHMJXJ Posted October 23, 2020 Posted October 23, 2020 Yep. Probably a good call. Rust/rot is always worse than what you see.
