1J7FJ26EXLL173188
Brokeboi
My 90 MJ, 2.5l 4cyl, 4x4 with manual trans. Sitting on 33x12.5 wrapped around 15" wheels. It runs well enough, albeit underpowered for my taste. Located in WA state. Paint was bad so I rattle canned it to keep the rust off until I do more work and decide to fix the massive dents in cab/bed and do a proper paint job. Door stickers are gone, so i don't know any more than this, but its a fun little truck and makes me smile.
*X1 TRIM STYLE X1 - CLOTH BENCH
-SA Charcoal
172 Zone 72-Portland
1AA U.S. Dealer Retail
4HC
ALA
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX  Maint. Free Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMF 4.10 Rear Axle Ratio
DRJ 175MM Rear Axle
EPD ENGINE - 2.5L I4 TBI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KDA STRIPE/BADGE/MOLDING/COLOR
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PE4 COLORADO RED CC PRI PNT - HE4
QE4 COLORADO RED CC SEC PNT - HE4
RA8 Delete Radio
SBA Power Steering
SCB Perforated Steering Whl
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z63 Left Front Spring Group XII
Z82 Right Front Spring Group XI
Build date 11/8/89
Body code JL61
  • 4 months later...
  • 2 years later...
