Transmission and 4 liter inline 6
AX15 or NV3550 would both be fine. The external slave bellhousing started in 94. Personally I’d just spring for a new ax15. Went through several uses and rebuilds before I got a good one. Keep in mind too that the XJ/MJ ax15 clocks the transfer case down slightly for better clearance although you can make the YJ/TJ version work too.
