MiNi Beast Posted August 2, 2021 Share Posted August 2, 2021 Little at a time. All progress. Looking good. Link to comment Share on other sites More sharing options...
The86manche Posted August 2, 2021 Author Share Posted August 2, 2021 Filling it in, cleaning it up. I don't even remember how I found them but while I was toiling away I found a few more soft spots on the unibody that I ended up cutting out and patching. Link to comment Share on other sites More sharing options...
The86manche Posted August 2, 2021 Author Share Posted August 2, 2021 Just now, MiNi Beast said: Little at a time. All progress. Looking good. Thank you! Not even done the photo dump on progress. Haha Link to comment Share on other sites More sharing options...
The86manche Posted August 2, 2021 Author Share Posted August 2, 2021 I guess I missed a photo on the firewall repair? That was actually a tough spot to do not going to lie. But, burned it in, sleep it up and coated it. Back to the rocker! If you twist your head upside down you can see rocker patches and pieces being cut out. I also finished up the unibody Link to comment Share on other sites More sharing options...
The86manche Posted August 2, 2021 Author Share Posted August 2, 2021 Shmootsed the rocker with some mud And ground down and sealed the unibody with some sem rust encapsulater. Kinda clear and thick qnd sticky like honey and will run down your hands if your not careful lol I seam Sealed and coated it too with some undercoat. Another spot I was aware of that I couldn't leave be was the left rear wheel well area. Which turned out to be more than I though it was. Like this whole project has been.. lol This turned out to be a lot easier than I thought it would be and I was happy with the results. I did grind, seam seal and coat the outside, I didn't leave it with visible welds but I don't have a photo of that. Reassembly! Took some time to clean up and out somoof it as I put it back together. The door panel is one of several spares I have for this jeep. And have to say.. Even with the mess.. I still love this interior. Link to comment Share on other sites More sharing options...
The86manche Posted August 2, 2021 Author Share Posted August 2, 2021 I have dome a lot more work to it than this. I just haven't taken any more photos. Front lower control arms were so shot the metal sleeve just fell out of the bushings. So they were replaced. I ended up patching another piece of the floor on the driver side for the seat brace. I fixed a botched wiring job/repair someone did. At one point in time it had a viper security system.. for whatever reason? it already had one factory.. but they cut it out and left nubs of wires and soldered wires wrapped in electrical tape. So one at a time I cut soldered and heat shrunk and wrapped the whole loom in electrical tape. The fenders were fully secured, front skid plate, tcase skid, power antenna, I started installing the wheel liners too. I took it for a good long drive yesterday and both me and the jeep got to experience deathwobble for the first time! 65-70 was a no go. So cruised at 60 while I pondered what could be causing it.. Still don't have an answer but I'll be checking things and getting an alignment in the hopes that's the issue. And about 20 minutes home from its voyage the front left caliper started sticking bad. You could smell the scorched rotor. So I have to address that now too. And the vehicle display was being buggy so I pulled that out to reflow the soldered spots and changed two expanded capacitors. It's been a long road but the list is getting smaller Link to comment Share on other sites More sharing options...
Pete M Posted August 2, 2021 Share Posted August 2, 2021 excellent work! so when do you start hitting the car shows? Link to comment Share on other sites More sharing options...
The86manche Posted January 26, 2022 Author Share Posted January 26, 2022 On 8/2/2021 at 3:08 PM, Pete M said: excellent work! so when do you start hitting the car shows? Never saw your post on this pete! I actually sold the ol girl to an enthusiast out in Ohio, mid last fall. Link to comment Share on other sites More sharing options...
Pete M Posted January 26, 2022 Share Posted January 26, 2022 sounds like it's in good hands. Link to comment Share on other sites More sharing options...
Jlindsey86 Posted January 27, 2022 Share Posted January 27, 2022 Such a sweet ZJ! Link to comment Share on other sites More sharing options...
The86manche Posted January 28, 2022 Author Share Posted January 28, 2022 5 hours ago, Jlindsey86 said: Such a sweet ZJ! I loved that zj, it was so nice. Do miss it a bit. Link to comment Share on other sites More sharing options...
