Renoenvy08 Posted September 3, 2020 Share Posted September 3, 2020 How do you pull the pinion shaft on a front D30? When I checked the hole I couldn't find any kind of pin Link to comment Share on other sites More sharing options...
Andy in Pa Posted September 3, 2020 Share Posted September 3, 2020 Do you mean when pulling the center shaft out of the carrier on the D30? If so, its either a roll pin which needs to be tapped out with a punch, or a threaded pin that will have a allen head or torx head to loosen. This looks like a roll pin, so tapping it out with a punch should do the trick. Link to comment Share on other sites More sharing options...
Renoenvy08 Posted September 3, 2020 Author Share Posted September 3, 2020 K, I tried using a punch but I couldn't get it to move. I'll stop and get a different one.thanks Link to comment Share on other sites More sharing options...
silvertwinkiehobo Posted September 3, 2020 Share Posted September 3, 2020 That could be a 'headed' pin, looks like a square drive? You at least should try to see if it'll turn before trying to tap it out. But, after a second look, I think I see a split along the side, at the 2:00 position. Link to comment Share on other sites More sharing options...
MancheKid86 Posted September 3, 2020 Share Posted September 3, 2020 your hitting it from the wrong side,its shouldered on the other side of the carrier so its only goes in/out one way that is the side for roll pin installation it has a larger diameter. the other side has a smaller diameter and is meant for removal hope this helps Link to comment Share on other sites More sharing options...
Renoenvy08 Posted September 8, 2020 Author Share Posted September 8, 2020 Well I have the upgraded axle in, getting ready to take it out on a test drive. Thank to everyone who gave me advice. As a bonus this just arrived a day early. Think my next upgrade is going to be the booster Link to comment Share on other sites More sharing options...
amsuco Posted September 8, 2020 Share Posted September 8, 2020 4 hours ago, Renoenvy08 said: As a bonus this just arrived a day early. I hope that you like them! I see a sale come through every so often, but Amazon doesn't tell me who the buyer is. Once in awhile someone will leave a review. That's about the only clue I have. Link to comment Share on other sites More sharing options...
Renoenvy08 Posted September 12, 2020 Author Share Posted September 12, 2020 Well I shouldn't have said anything, my booster started sucking air so now I'm putting in a new booster after white knuckling it for two days over the Tacoma narrows bridge and back just waiting for payday Link to comment Share on other sites More sharing options...
MiNi Beast Posted September 12, 2020 Share Posted September 12, 2020 sucking air eh? So does this mean replacing it is in order 🤔? Link to comment Share on other sites More sharing options...
