RKTJeep Posted August 15, 2020 Share Posted August 15, 2020 I ordered a replacement EGR valve from Rockauto, but it is significantly different from the factory one (much larger diaphram). It came without the vacuum transducer and does not have a port to connect the original vacuum transducer. From the limited information I can find, it looks like the transducer interlocks the EGR operation to only open when there is exhaust pressure. Has anyone ran this setup or similar EGR without the vacuum transducer? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted August 15, 2020 Share Posted August 15, 2020 You ordered the wrong EGR Link to comment Share on other sites More sharing options...
RKTJeep Posted August 15, 2020 Author Share Posted August 15, 2020 Just now, Strokermjcomanche said: You ordered the wrong EGR Can you point me in a direction for the correct one? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted August 15, 2020 Share Posted August 15, 2020 15 minutes ago, RKTJeep said: Can you point me in a direction for the correct one? 53004867 is the part number , I don't see them come up very often though. Link to comment Share on other sites More sharing options...
SVPete Posted August 16, 2020 Share Posted August 16, 2020 Perhaps it is a new design that eliminates the transducer by integrating it's function into the valve. Maybe that's why there are two holes in the body of the replacement EGR. Does it bolt up? Link to comment Share on other sites More sharing options...
rokinn Posted August 16, 2020 Share Posted August 16, 2020 I bought one of these from NAPA a couple of years ago. I don't remember paying this much then but we know how that goes. https://www.napaonline.com/en/p/CRB226422 Link to comment Share on other sites More sharing options...
omega_rugal Posted August 17, 2020 Share Posted August 17, 2020 On 8/16/2020 at 10:04 AM, SVPete said: Perhaps it is a new design that eliminates the transducer by integrating it's function into the valve. this, have you tried it? Link to comment Share on other sites More sharing options...
RKTJeep Posted May 30, 2021 Author Share Posted May 30, 2021 ********* UPDATE SOLVED ********* So the RockAuto replacement EGR caused it to fail California Emmissions for NO2. After some diagnosis, I found that the vacuum pressure was not enough to actuate the EGR properly. Luckily was able to to source the a used OEM EGR on the forum here, I couldn't find an EGR era 4.0 in the LA area salvage yards. It passed emissions at the very next test. So if you have a used OEM EGR don't throw it away. You might want to post it up here for those in restricted areas. I haven't been able to find a new OEM equivalent, so we'll be dependent on salvage and community used parts as far as i can see. Link to comment Share on other sites More sharing options...
IDMT Posted May 30, 2021 Share Posted May 30, 2021 Thanks for the update! Link to comment Share on other sites More sharing options...
