Pete M Posted August 11, 2020 Share Posted August 11, 2020 not sure what it goes to. I see a couple V-belts... https://www.ebay.com/itm/NOS-AMC-JEEP-DEALER-ACCESSORY-AC-AIRCONDITIONING-KIT-OEM-CHEROKEE-COMANCHE/383479464806?hash=item5949284366:g:wokAAOSwemdefLga Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 11, 2020 Share Posted August 11, 2020 I think and judging by the early accessory part number, this would fit either the 2.5L carb engine or a 2.8L. Theres still a couple NOS AC kits at dealers but they are still very much expensive. Link to comment Share on other sites More sharing options...
TheDude Posted August 11, 2020 Share Posted August 11, 2020 not sure what it goes to. I see a couple V-belts... https://www.ebay.com/itm/NOS-AMC-JEEP-DEALER-ACCESSORY-AC-AIRCONDITIONING-KIT-OEM-CHEROKEE-COMANCHE/383479464806?hash=item5949284366:g:wokAAOSwemdefLga Can anyone confirm those brackets fit an 86'?Since the compressor is setup for V belts I'm wondering if it's for an FSJ.Founding Member of the Comanche Preservation Society Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 11, 2020 Share Posted August 11, 2020 Those brackets probably will fit an 86. Course the pert number doesn't exist anymore so I can't see the years but in 87 AMC went to the more solid bracket set up for AC. Link to comment Share on other sites More sharing options...
coheed Posted August 11, 2020 Share Posted August 11, 2020 The inspection date is 1984 so it could only fit the 86's. From my recollection of the brackets on my 2.8 I'd guess it was for a 2.8. Link to comment Share on other sites More sharing options...
Chad R Posted August 11, 2020 Share Posted August 11, 2020 If this helps my 86 2.5L had dealer installed ac that had v-belts. I took it off because the bracket broke and cause belt issues Link to comment Share on other sites More sharing options...
Chad R Posted August 11, 2020 Share Posted August 11, 2020 Hear is the compressor Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 11, 2020 Share Posted August 11, 2020 Looks like the same mess chunk has. Link to comment Share on other sites More sharing options...
