rylee144 Posted July 14, 2020 Share Posted July 14, 2020 I'm doing an axle swap in my comanche. I got the axle from a 91 cherokee but I'm pretty sure it was not original to that jeep. The shaft was broken and I don't know what to order. Here is a picture and can get more if needed. Guy at the parts store didnt have any ideas Link to comment Share on other sites More sharing options...
rylee144 Posted July 14, 2020 Author Share Posted July 14, 2020 Could it be this? https://www.carparts.com/details/Jeep/Cherokee/Crown/Axle_Shaft/2001/4874303.html?TID=gglpla&origin=pla&utm_source=google&utm_medium=pla&utm_campaign=8683078729&gclsrc=aw.ds&&gclid=CjwKCAjwr7X4BRA4EiwAUXjbt0wT4U1Y8EJuMHdEz8ujzZ14LWw10PX8KaJVYsQyUbvP8m_oGg6pHRoCy5wQAvD_BwE Link to comment Share on other sites More sharing options...
BeatCJ Posted July 14, 2020 Share Posted July 14, 2020 Appears to be right. It should have some lengths to check. Crown will be serviceable, probably offshore origin. That price seems a little high to me, but I haven't shopped around. Maybe that's OK for a complete assembly. OOPS, my bad. Google says I'm wrong. Link to comment Share on other sites More sharing options...
Dzimm Posted July 15, 2020 Share Posted July 15, 2020 Agreed, looks like the short side of a Dana 30. You have a picture of the actual axle assembly? It'll be easier to identify with that. Link to comment Share on other sites More sharing options...
JMO413 Posted July 15, 2020 Share Posted July 15, 2020 Looks like the short side of a Dana 30 to me. I believe they are pretty interchangeable through the years, U-joint side being the difference. Link to comment Share on other sites More sharing options...
rylee144 Posted July 15, 2020 Author Share Posted July 15, 2020 Link to comment Share on other sites More sharing options...
Dzimm Posted July 15, 2020 Share Posted July 15, 2020 Yeah that's a Dana 30. Its high pinion without a vacuum disconnect so its from somewhere in the neighborhood of a 95-99 XJ axle. Link to comment Share on other sites More sharing options...
rylee144 Posted July 29, 2020 Author Share Posted July 29, 2020 I was just told a ABS or none ABS shaft would work. Is this true? Link to comment Share on other sites More sharing options...
Eagle Posted July 29, 2020 Share Posted July 29, 2020 10 hours ago, rylee144 said: I was just told a ABS or none ABS shaft would work. Is this true? Either should work in a non-ABS axle. The ABS shaft should have a tone ring, and I believe the ABS shafts had the larger U-joints. Link to comment Share on other sites More sharing options...
