70barracuda Posted May 21, 2020 Share Posted May 21, 2020 Anybody find new manufactured seat belts that work? closest ive found are these : https://www.seatbeltsplus.com/product/Q8496P-4DR.html found a couple of threads about it but they fizzled out without a definite answer. Link to comment Share on other sites More sharing options...
AZJeff Posted May 21, 2020 Share Posted May 21, 2020 Do you want OEM equivalent to attempt to restore your MJ to factory appearance, or just good seat belts? I used these guys, and their belts are perfectly acceptable, but they are not a perfect match to OEM. However, I went with the type of female buckles that are attached to a stiff cable, rather than the fabric type, as they are easier to find with a bucket seat and a console. Link to comment Share on other sites More sharing options...
70barracuda Posted May 21, 2020 Author Share Posted May 21, 2020 1 hour ago, AZJeff said: Do you want OEM equivalent to attempt to restore your MJ to factory appearance, or just good seat belts? I used these guys, and their belts are perfectly acceptable, but they are not a perfect match to OEM. However, I went with the type of female buckles that are attached to a stiff cable, rather than the fabric type, as they are easier to find with a bucket seat and a console. Just after some good seat belts. I figured they wouldn't be perfect OEM matchable. 30 year old seat belts just don't seem like a great idea to use especially since I might race this thing. Biggest concern was fitment because they are for an xj. As long as I don't have to cut up trim and they work I'm good. Link to comment Share on other sites More sharing options...
70barracuda Posted May 22, 2020 Author Share Posted May 22, 2020 https://www.seatbeltsplus.com/product/WSCH256P.html These look almost like a dead similar set up as the OEM style. Link to comment Share on other sites More sharing options...
Crash Posted May 22, 2020 Share Posted May 22, 2020 I run WJ belts. Cuz I had them available in a parts jeep. If you do this, use the driver on passenger and vice versa. Because of how the brackets and belt mount . Link to comment Share on other sites More sharing options...
knever3 Posted May 25, 2020 Share Posted May 25, 2020 https://teamtechmotorsports.com/Give them a call, that's what they do. They sew them on site. Good friend of mine bought a roll of new seat belt material and dropped off his old buckles and they made him a set that was OEM that looked new.The result was beyond amazing!Sent from my SM-G920P using Tapatalk Link to comment Share on other sites More sharing options...
70barracuda Posted May 28, 2020 Author Share Posted May 28, 2020 So the universal 3 point style from seatbelt plus is a pretty much a drop in replacement. Only thing I had to do was enlarge the hole on the retractor. Everything else bolted right in and it fit behind the b pillar perfectly. They also look exactly like the OEM belts. Buckles and all. Link to comment Share on other sites More sharing options...
kriswinner Posted May 28, 2020 Share Posted May 28, 2020 11 hours ago, 70barracuda said: So the universal 3 point style from seatbelt plus is a pretty much a drop in replacement. Only thing I had to do was enlarge the hole on the retractor. Everything else bolted right in and it fit behind the b pillar perfectly. They also look exactly like the OEM belts. Buckles and all. @70barracuda: Just for clarity, which ones did you purchase? https://www.seatbeltsplus.com/product/WSCH256P.html or https://www.seatbeltsplus.com/product/Q8496P-4DR.html ? Enlarging the hole on the retractor...just trimming the b-pillar trim? Glad you were able to find something that matched! Link to comment Share on other sites More sharing options...
70barracuda Posted May 28, 2020 Author Share Posted May 28, 2020 7 minutes ago, kriswinner said: @70barracuda: Just for clarity, which ones did you purchase? https://www.seatbeltsplus.com/product/WSCH256P.html or https://www.seatbeltsplus.com/product/Q8496P-4DR.html ? Enlarging the hole on the retractor...just trimming the b-pillar trim? Glad you were able to find something that matched! First one. The Cherokee specific one seemed like it could work but that bracket on the retractor worried me so I went for universal. There are a lot of different styles but that's the one that worked for me. And just enlarging the one hole. No b pillar trimming required at all. Link to comment Share on other sites More sharing options...
