The comanche is going 4 wheel drive
Most likely, 3.07s. Manual MJs and XJs usually has 3.07s and autos had 3.55. If you want 3.55s, swap the XJ rear axle into the MJ. All you would need to change the rear axle is weld on different spring perches. Oh, these questions would go in the Mods and Repairs section. I’m sure @Pete M will move it for you.
10 minutes ago, Chriscross said:
Thanks..that's What I was thinking
.sorry for posting in the wrong spot..I'm kinda a analog guy..lol
You’re all good. We were all new to this at one point!
Unless otherwise specified, a manual trans would’ve had 3.07 gears... from the factory. 33 years later, it may no longer be original.
If you’re going to the trouble of changing axles, unless you can find one that bolts in, get a better axle than a d35.
