Chunk, A 1984 XJ
Lets see, where to begin. I spent a few hours collectively trying to figure out my fuel gauge issue. Same issue with another gauge, same issue with a later cluster but a little less sensitive. I added a ground thinking that was part of the issue and it wasnt. So I am now looking at the sender being an issue which will be incredibly odd but I shall see. Luckily I have a couple sending units to goof with and I plugged it in place of the one in the tank, recreated the sloshing effect and didnt have the issue on the gauge. I worry that I may end up wasting my time on chasing this bizarre issue. I even tested the current sending unit outside of the tank but I didnt account for any sloshing or anything like that so it could be busted in a weird way.
Just 84/Renix things.
Still have some stuff to do like the wiper bushings, oil change, cruise and AC. Gonna try that free zone stuff I acquired a while back.
I also got this done:
Whats different? Well I made some custom brackets to get it in place. Thanks to some examples of this radio for the XJ on ebay, I was able to copy the brackets to a degree and get this radio in place correctly. Im pretty proud of the few hours I spend cutting and designing the brackets. Now it wont flop around or move with the XJ/MJ specific radio adapter bracket.
  • Replies 489
So I did the wiper bushing repair today. Linkage is less loose now and shouldnt part where ever it wants.
I also replaced the shift boot at the floor today. Not the one on the console but the body.
I had tremendous amounts of heat coming through the console and I knew the boot was nonexistent but man was it like I had the heater on.
Here they are side by side. Sure the screw holes dont line up but heres the best part, that base is rubber. Not metal with rubber like the old one. Might bite me in the butt later but we will see.
New one on top of the old one. Perfect fit!
So I took some screw drivers, lined up two holes and drilled the rest
Installed. Doesnt even look out of place really.
And console back on. No issues shifting or anything. Now I should have no heat coming through anymore.
And if youre wondering:
Theres the part number. Its for a Kenworth big rig.
I got cruise control to work. Just need to tune it to get it dialed in.
Got AC working too. Turns out a Schrader valves gasket was bad. As soon as I pulled it out, there was a piece of rubber that was supposed to help seal the system but failed.
So I put in the Free Zone, no leaks, temp gets down to about 45*, not a performer but better than sourcing and converting to 134. Curious as to how it will handle in the summer. Should see 50* which will be better than nothing. I imagine driving around will make it colder as it cools off the condenser more.
5 minutes ago, Salvagedcircuit said:
:beerchug:
Just have to figure out what orientation now :banana:
I think I'll test it out with tape or cardboard to settle on the size of it
Sounds like the smart way to do it. If it helps any, the MJ bed mat has the AMC logo on, with 'Jeep' next to it in the center of the mat.
57 minutes ago, Salvagedcircuit said:
The big question: Should I do that to my new roll up tonneau cover? :brows:
I'd like to see that. I agree that the red, white, and blue would be the way to go with it. I wonder how it would look if you painted an entire rectangle white, then did the red and blue over the top. The white might help with coverage and I think leaving a little white perimeter around the whole thing might make it pop a little bit more. Something like this logo.
I just have to find a red that does not fade in the sun! :roflmao:
So I installed a diode to rectify the back feeding issue. Worked like a charm.
I also yanked out the fuel sending unit and found the float level to be on the fritz! So I swapped out the unit and got hell of a surprise to see I was low on gas! Haha. So I am gonna inspect that FSU and see why the hell its behaving like this.
Anddddd trailing behind that surprise of low fuel was a nasty one of a failing fuel pump. What a chase that was and damn near exhausted me while almost running out of ideas. Swapped to a different sending unit with an original AMC pump that believe it or not, still works. I want to go back to the 86 unit and I probably will when I get the right pump as this unit holds a smaller than what were used to seeing pump
Funny enough, this is the unit that came with the fuel tank and I didnt do a damn thing to it other than swap the pump to a different unit and then back and then swapped the float reader to find the pump failing.
Also got cruise control finally dialed in. I found a pic online of an 86 MJ with the 2.5L and it had cruise control. So this gave me an idea to move the servo to match the location of where AMC mounted it using the correct mount, I actually happen to have two of to my surprise and put it on along with using a 4.0L cable. Finally a 4.0L part I can use! Haha.
Ok! After spending a few hours taking a booster out, putting the new one in, taking it out, putting it in again and yadda yadda till it was right I finally have a really damn good braking XJ.
Here’s the old and it’s shape
Heres the 84-90 compared to the 91 and up
If you ignore the protruding push rod, they’re pretty damn close to being the same. Except for one detail. The hole for the brake switch is too small. So I drilled it out. Got the size close to right, minus some welding and dremel work to make it close to the other booster. But I got it, brake lights work, brakes damn well. Even got the rears to lock up after a quick acceleration to 30mph.
All in all, it was worth the effort and no more failing booster and hopefully my idle will no longer be at 1500 when driving and starting. Which means I’m gonna have to adjust the ISA again at some point.
12 minutes ago, Pete M said:
I'm sure it still had some flex, but it looks old enough I could snap it in half.  :crazy:
What’s insane is it still very much has flex to it. It’s not dry or anything. Just flatter than round and cracking and can be ripped.
