Jackrabbit41 Posted April 23, 2020 Share Posted April 23, 2020 Wanting to know stock brake line size and thread. I need to order some longer stainless steel lines Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Eagle Posted April 23, 2020 Share Posted April 23, 2020 Are you asking about the hard lines (tubing), or the flex hoses at the front calipers and rear axle? Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted April 23, 2020 Author Share Posted April 23, 2020 5 hours ago, Eagle said: Are you asking about the hard lines (tubing), or the flex hoses at the front calipers and rear axle? I am wanting to know what thread and size the hard lines are so I can attached longer braided stainless steel lines to account for my axle droop without ripping them out Link to comment Share on other sites More sharing options...
Limeyjeeper Posted April 23, 2020 Share Posted April 23, 2020 3/16 with 3/8-24 fittings for the most part. It does get a little tricky at the proportioning valve and master cylinder. Some of those fittings are different Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted April 27, 2020 Author Share Posted April 27, 2020 At work so I can’t go actually look but need to know brake line threads. I know the size is 3/16th but what threads do stock hard like fittings have? Trying to order stainless steel braided lines and adapters to AN and need to know stock threads. Thanks Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Limeyjeeper Posted April 27, 2020 Share Posted April 27, 2020 Mainly 3/8-24 except for between the Master Cylinder and Distribution block. Some of those are different. They are a mixture of 7/16 - 24 and 1/2 - 20. Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted April 27, 2020 Author Share Posted April 27, 2020 Mainly 3/8-24 except for between the Master Cylinder and Distribution block. Some of those are different. They are a mixture of 7/16 - 24 and 1/2 - 20. So would the port coming out of the distribution block to the driver front brake be 3/8-24? I see very one online saying it’s 3/16 everywhere not 3/8sSent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Minuit Posted April 27, 2020 Share Posted April 27, 2020 3/16" is the line size, not the fitting thread size. I do not know what the fitting sizes are other than the brake bleeders, which are also 3/8-24. Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted April 27, 2020 Share Posted April 27, 2020 Didn't you already ask these questions and get the same answers in your other "Brake Line Question" thread? Why the repeat? Also, a great feature that you can use is to google "site:comancheclub.com *search criteria*" without the quote marks. It will limit the search to this forum only. Its a great way to sift through threads quickly. For instance, in 5 minutes I found the following thread, which should answer your questions completely. Link to comment Share on other sites More sharing options...
Eagle Posted April 28, 2020 Share Posted April 28, 2020 Duplicate threads merged. The brake lines are still 3/16", and all the fittings except at the distribution block are still 3/8-24. Link to comment Share on other sites More sharing options...
Limeyjeeper Posted April 28, 2020 Share Posted April 28, 2020 😁 Link to comment Share on other sites More sharing options...
