Speedometer cable
I broke the perfectly good old one when replacing the volt meter. It still worked but was real shakey. Bought a new one and installed it. It's completely dead now. 89 Eliminator. What did I miss. Everything fit like a glove. New cable is about a foot longer than the old. Got creative laying it out but no sharp bends or loops.
89 Comanche
Eliminator
2wd
4.0L
5 speed PukeGoat
Factory Original
This happened to me. My problem was the end behind the cluster popped loose during re-assembly. I would check both ends and make sure the cable hasn't come undone, or that the inner core hasn't slipped too far (forward or back) in the protective sheath, so that its not contacting either the gear in the transfercase, or the speedometer
x2. It popped out just enough to miss the receptacle when reassembling. Twice
So apparently i didn't lock it onto the back of the cluster. Small detente didn't lock it. Push harder and it locks onto it. Has to click twice. Works great! Now for the oil leak I found while fixing this.
89 Comanche
Eliminator
2wd
4.0L
5 speed PukeGoat
Factory Original
